Page 103 of 198 FirstFirst ... 35393101102103104105113153 ... LastLast
Results 1,021 to 1,030 of 1974
  1. #1021
    Quote Originally Posted by gaucho View Post
    what do you mean, the cable is original, but I've bought it like 2 years ago.
    Gaucho: OK - thanks for the response. As you will doubtless already know since you purchased a "genuine" Ross-Tech product 2 years ago, the cable isn't delivered with software. Unlike fake cables which come with their own out-of-date software on a CD, users of genuine RT cables must download the associated software from the RT web-site.
    My suggestion is to do just that with your genuine RT cable - go to the webpage HERE and update your software to the latest version - problem solved!!
    If your genuine RT cable is operating on such an old software version, then you run the danger that it is incompatible with the newer (24 bit) MIBII control modules - which can cause serious problems (assuming that you haven't got HEX-NET)! For no other reason than this - it's definitely a good idea to update the firmware in your cable which will happen when you load the newer RT software version
    As you will also doubtless be aware updating to Ross Tech's latest software is done at no additional cost to the user. Why have you not done this since purchasing your cable "like 2 years ago"?
    Odd that you have persisted using such old software for such a long period of time with your genuine RT cable when there is such an easy no-cost option to update that provides such obvious benefits..........hmmmm!!!. Of course, the risk of destroying a fake cable by updating to the newer Ross Tech software doesn't apply in your case because it's a genuine cable - just an odd co-incidence (I think)
    Have a great Brazilian Christmas and a safe (and truth-filled) New Year!
  2. #1022
    Dec 2016
    brazil
    I have not used the cable ever. When I bought it said "genuine cable". My car was still on warranty. Now that it's not anymore I thought about doing some modifications. That's why I am asking if the ones I've listed are compatible with it. I know nothing about vcds.
    One more thing: this is not ross forum. So I'm starting to being annoyed but this intrusion with my cable origin and etc. I've asked some simple questions, if you don't have an answer for what i've asked I don't want you to interfere with from where or anything else about my cable. I hope you understand.
  3. #1023
    Gaucho: Understood!!
  4. #1024
    Mar 2015
    Warner, QLD
    VCDS (VAG-COM) codes and programmable options for Golf Mk7
    Ya gee DV52! it's clear you don't contribute anything at all to the VCDS thread, and obviously have no knowledge or devoted any of your time to understand and help other members with their often complicated VCDS questions.
    Bugger off will you? VCDS (VAG-COM) codes and programmable options for Golf Mk7
    Merry Xmas to you and your family, and thanks for all the help you have provided throughout the year! VCDS (VAG-COM) codes and programmable options for Golf Mk7VCDS (VAG-COM) codes and programmable options for Golf Mk7
    Golf MK7 103TSI Highline Wagon | Limestone Grey | DAP2
    Golf MK7 110TDI Highline Hatchback | Tungsten Silver | DAP
  5. #1025
    Dec 2016
    brazil
    Quote Originally Posted by agentthumb View Post
    Ironic guy right? I've made it very clear I was talking about the cable origin thing, nothing else. I don't know DV52 since I am new to the forum. I have no reason though to not believe he is a great contributor.
  6. #1026
    Mar 2015
    Warner, QLD
    Well, you have certainly got a way to:
    A. Introduce yourself to a forum as a new member
    B. Blind side one of the most knowledgeable member on VCDS on one of your first posts.
    Well done. And your question has been answered by DV52, update your software and you are good to go. It's free.
  7. #1027
    Dec 2016
    brazil
    About B I will not go into it again, thanks. I believe DV52 as a mature person certainly understand that there's no wickedness in my post.
  8. #1028
    Oct 2016
    Sydney, NSE
    After I made the change to get rid of the warning message on the infotainment screen, I noticed that the car graphics are now station wagons? Amy idea how to change it back to a hatch?
  9. #1029
    Quote Originally Posted by jimmyjamesred View Post
    Jimmyjames: Not sure how this has happened, but I suspect (guessing really) that your MIB thinks that it's installed in a Golf Sportswagon! The way that the MIB is told about the identity of the car is through Bytes 0-3 of the code-string on the module @ address 5F. Here's how these Bytes are structured:
    What are the values of these Bytes on your car? If these Bytes are 027300, what is the complete code-string on your car
  10. #1030
    Oct 2016
    Sydney, NSE
    What are the values of these Bytes on your car? If these Bytes are 027370, what is the complete code-string on your car
    See screenshot. I've got a MY17 GTI hatch.
