Originally Posted by
BlitzAce
I'm not all too familiar here, so can anyone point what page is about increasing the brightness of the LED tails for brake? Since I retrofitted it from the normal halogen tails, I understand the LEDs can be made brighter with VCDS? Currently the brake lights are half decent in my opinion during the day, at night it's ok.
BlitzAce: Hello. First-off I must say that there are a multitude of different retrofitted LED lamps/fittings on the market and each has their own unique characteristics. Plus, each individual person's perception of lighting is also equally unique! This said, I'm surprised at your observations - still, I guess that anything is possible where retrofitted LEDS are concerned!!
So the two particular "Leuchte-sets" that manage the outside brake lights on the tails are:
- Left-side lamp: Leuchte20BR LA71
- Right-side lamp:Leuchte21BR RC8
Within each of these Leuchte-sets, the adaption channel that tells the Body Control Module (BCM-or what VCDS calls "Central Elec.") is the one with the term "Lasttyp" in its title. Becasue your car was factory fitted with incandescent lamps, I suspect that the current settings for the brake-lights are as follows:
- ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 >13 - Bremsleuchten
- ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 >13 - Bremsleuchten
Since you have retrofitted LEDs in place of the old incandescent lamps, it might be more prudent to change the settings for the channels above to an LED type (perhaps something like 34 - LED Bremsleuchten)
It might also be worth checking the "dimming level" of the Leuchte-sets that supply your new LEDs. These are controlled by the following two adaption channels
- ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20
- ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21
Again because your car was factory fitted with incandescent lamps, I suspect that the setting for these channels on your car is 100. This is also the setting that VW has on their factory fitted LED tails. It is possible to increase this number to 127 (only if the "lasttyp" channel has an LED value), however problems often result if a value higher than 100 is used on the Brake function, and my observation (from viewing the PWM wave-form from the Leuchte-channel on an oscilloscope) is that full voltage is provided at 100
