Page 94 of 198 FirstFirst ... 44849293949596104144194 ... LastLast
Results 931 to 940 of 1974
  1. #931
    Quote Originally Posted by Kiaorana View Post
    Actually, I'm wrong!
    It can be achieved with this harness apparently. Cool stuff
    =http://www.vcdssydney.com/store/p12/Dynamic_Indicator_Adaptor_for_Original_OEM_Genuine _Tail_lights.html
    Sent from my SM-G925I using Tapatalk
    Kiaorana: Hello again. I could be wrong (I often am), but I believe that it's more than just a cable/harness that's required to make the turn-signal LEDs sequence in the manner shown in the video.
    As I'm sure that you already know, there is only one pin that is brought-out on the connector for each of inner/outer turn signal clusters. Now it has been a very, very, very long time since I sat in classroom to be taught electronic design, but it ain't physically, or electrically possible to implement the LED chase effect if you only have access to one pin for the entire cluster segments!
    I believe that Deutsche Auto Parts sell a harness that flashes the entire inner cluster a few seconds after the outer cluster, but it's not a true LED chase as per the video. They also want your first born child as the price for their harness (I recall)
    The only way to implement LED chaser is to either design the effect into a third party fitting from scratch, or to break-open the VW fittings and access each LED individually. I suspect that the former option applied to the tails in the video!! I would be interested to know at what price these units are sold - I suspect that the seller charges a price close to the annual budget of a small African nation!!
    PS: your link is broken!
  2. #932
    Quote Originally Posted by fonsii View Post
    thanks for the reply! see image^
    so upon braking the red led at the indicator does light up, but otherwise it doesn't.
    fonsii: OK, that's much clearer - thanks for the claification. I don't have LED tail-lights on my mk7, so I'm not accross the detail for the one LED segment at the intersection of the two clusters. What I do know however is that it's not possible to access this segment on its own from outside the housing. Each of the clutters (as a complete unit) has a single wire that is brought out of the housing and that is terminated at the connector.
    So, one of two options is possible with your problem (I think): Either the effect that you observe is normal (I don't know), or there is a fault in the intersecting LED at the point that you identified - in which case it's either a chuck-out job, or a warranty matter)
    Perhaps someone else here who has a mk7 with LED tails can comment?
  3. #933
    Aug 2015
    Sydney, Australia
    I give you - 1 African nation
    Boo, hiss
  4. #934
    Aug 2015
    Sydney, Australia
    This is of my 2016 Golf R, with headlights on, no brake applied.
  5. #935
    yeah, the LEDs there definitely work when brakes are applied, so the LEDs are not faulty.i guess i dont' mind it as much but once my friend pointed it out to me i can't unthink it -.- thanks anyway! i've already tried dealing with VW in regards to a few little things and i ended up wanting to stomp on their head on a kerb. so i might just not deal with VW right now about the leds...
    I take photos | threetwoone.com.au
    I also drive a MY16 R
  6. #936
    Aug 2015
    Sydney, Australia
    Are both tail lights the same?
  7. #937
    Sep 2016
    Europe
    How to kill alarm loud sound when You open door when car in gear? I have DSG in my car.
    2016 VW GOLF 1.4 TSI DSG
  8. #938
    Dec 2013
    Hi Don,
    That's what I tho get too, hence why my first reply was that it was only possible with an aftermarket Tail Lights, it wouldn't work with OEM.
    But then I saw that harness which claims to do just that woth OEM tail lights.
    There's a video at the bottom, is that the same as what DAP is selling?
    Dynamic Indicator Adaptor for Original OEM Genuine Tail lights
  9. #939
    both the same. not even sure when it started happening
    Quote Originally Posted by danielb_c View Post
  10. #940
    Mar 2015
    Warner, QLD
    fonsii, skip to 1:05 of this video. I think this demonstrates exactly what you are talking about.
    https://www.youtube.com/watch?v=xJiANBAp8ps
    Golf MK7 103TSI Highline Wagon | Limestone Grey | DAP2
    Golf MK7 110TDI Highline Hatchback | Tungsten Silver | DAP
