Page 93 of 198 FirstFirst ... 43839192939495103143193 ... LastLast
Results 921 to 930 of 1974
  1. #921
    Sep 2016
    Sweden
    Thank you agentthumb for your answer.
    i can understand the safety regarding this but I would still like to remove that feature when I am in manual mode.
    the 1.4 tsi is a lovely little engine and has a lot of tourque from around 1500 to about 4000 rpm.
    the turbo on these engines are really small, and I mean really really small so it will not provide much boost over 4k. Therefore I don't want the gearbox to downshift so that the rpm goes to 4500-5000 like it does know.
    I hope I can make myself understood, it's been a while since I studied English in school
  2. #922
    my Brake/Indicator LED at the edge of my outter tails doesn't seem to like turning on (See Image)
    any ideas on how to turn them on?
    Attached Thumbnails Attached Thumbnails VCDS (VAG-COM) codes and programmable options for Golf Mk7-bbhez2j-jpg
    I take photos | threetwoone.com.au
    I also drive a MY16 R
  3. #923
    Aug 2015
    Sydney, Australia
    Hi, I've followed the below instructions (2016 Golf R), and I'm able to get the indicator and DRLs to blink alternately, however only when the headlights are on, or in 'auto' with headlights on (but not in 'auto' when headlights are off).
    Any suggestions on how I would get this to work while headlights are off?
    TIA
    Blinker opposite DRLs
    Central Electronics
    Security Code 31347
    Adaptation
    Search for LB4
    change the value in C4 from Standlicht allgemein (parking light general) to Blinken Links Dunkelphase (blinks with left indicator dark phase)
    Commit changes
    back to Adaptation
    Search RB32 and select Leuchte5 TFL RB32
    Change the value in C5 from Standlicht allgemein (parking light general) to Blinken Rechts Dunkelphase (blinks with right indicator dark phase)
    Commit Changes
  4. #924
    Quote Originally Posted by danielb_c View Post
    TIA
    Central Electronics
    Security Code 31347
    Adaptation
    Search for LB4
    Commit changes
    back to Adaptation
    Commit Changes
    Daniel: Hello. Now that's a very interesting set of "Leuchte" programming instructions indeed!! Where did you get them?
    Try this:
    1. Restore the original values of "C5" and "C4"
    2. Change the following:
    Adaptation channel Old Setting New Setting
    (12)-Leuchte4TFL LB4-Lichtfunktion E 4 not active Blinken Links Dunkelphase
    (15)-Leuchte4TFL LB4-Dimming Direction EF 4 maximize minimize
    (12)-Leuchte5 TFL RB32-Lichtfunktion E 5 not active Blinken Rechts Dunkelphase
    (15)-Leuchte5 TFL RB32-Dimming Direction EF 5 maximize minimize
  5. #925
    Quote Originally Posted by fonsii View Post
    fonsii: Nice picture, but I don't understand the question - alas! To which section of the tail-light fitting on the picture below are you referring (note that the tails have an un-lit border surrounding the LED clusters)?
  6. #926
    thanks for the reply! see image^
    so upon braking the red led at the indicator does light up, but otherwise it doesn't.
    Attached Thumbnails Attached Thumbnails VCDS (VAG-COM) codes and programmable options for Golf Mk7-exodcgr-jpg   VCDS (VAG-COM) codes and programmable options for Golf Mk7-untitled-1-jpg
  7. #927
    Aug 2015
    Sydney, Australia
    Try this:
    Thanks for replying Don!
    I've followed your table and have found that in 'dunkelphase' the drls and indicator flash in unison, so I've changed to 'hellphase' and now have the desired alternating effect. This is working irrespective of the light switch setting (auto, park lights, headlights, off).
    Perfect! Exactly what I was after. Thanks!
    Here's the link for where I found the instructions: [V5] ProBoards - Free Forums & Free Message Boards
    Edit: here's the result
  8. #928
    Aug 2015
    Sydney, Australia
    Hi,
    I'd be very keen to learn how to accomplish this indicator pulse, rather than the 'pace car' mod I have at the moment: https://youtu.be/DCn_YiJDrOo
    Any suggestions on coding?
    Daniel
  9. #929
    Dec 2013
    Hi,
    Daniel
    Hi Daniel,
    Unfortunately, it cannot be achieved with stock tail lights. You need aftermarket ones for that.
    I believe the ones you see in the video are those ones :
    Dynamic Indicator Adaptor for Original OEM Genuine Tail lights
    Sent from my SM-G925I using Tapatalk
  10. #930
    Dec 2013
    Hi,
    Daniel
    Actually, I'm wrong!
    It can be achieved with this harness apparently. Cool stuff
    https://=http://www.vcdssydney.com/s...il_lights.html
