Page 78 of 198 FirstFirst ... 2868767778798088128178 ... LastLast
Results 771 to 780 of 1974
  1. #771
    Aug 2015
    It seems to be the cars with the new RLHS (I think it stands for Rain, Light, Humidity Sensor?) that are struggling with this function.
  2. #772
    Quote Originally Posted by eden View Post
    Hello,
    1. I am new here on forum, please can you tell me its this to for Passat B8 ? I trying for days to make work rain closing but not working. I have RLHS rain sensor.
    2. I install folding mirrors, and i have activate in door control unit, but still not work. Its here one login code for activate folding mirrors ?
    Tnx
    eden: Hello and welcome to the forum. I don't know whether any of what I said above applies to a Passat B8 - that said, the car is also an MQB platform model, so I would expect that it shares many of the features of other MQB cars. Why not have a look at my tweak instructions and see if the same adaptation channels and Bits are on your Passat?
    As for your folding mirror question, you can download a copy of the USP Motorsports instructions in the link below. Towards the end of the document, you will find the coding changes - hope that it helps
    https://www.dropbox.com/s/k9h6y6w9bk...tions.pdf?dl=0
  3. #773
    Mar 2016
    Slovenia
    Tnx for answer. Yes the controler is the same for folding mirror. I try this later. But its posible to work without switch for folding mirrors ? I not changed this
    Here is my error from this control unit:
    65654 - Motor für Spiegelanklappung B11F6 13 [009] -
    Unterbrechung
    bestätigt - geprüft seit letzter Löschung Umgebungsbedingungen: Fehlerstatus: 00000001 Fehlerpriorität: 3 Fehlerhäufigkeit: 1 Verlernzähler: 220 Kilometerstand: 33529 km Datum: 2016.03.12 Zeit: 22:09:35
  4. #774
    Mar 2016
    Slovenia
    For rain closing i have try the whole your coding and is all accepted. But still not work. I have RLHS sensor
  5. #775
    May 2013
    the Netherlands
    Quote Originally Posted by Drive View Post
    Hey Chillout, e-manager and Hybrid disappears from the bottom menu after the modification?
    Oh yes, but that's not caused by the coding... it's because I sat in the car for >10 minutes, then these buttons disappear for some reason. When restarting the car, they will reappear.
    Chillout - great GIF!! Here's some other options that you might want to try!
    PS: Is it really that cold in the Netherlands!!
    Oh dear... I need to use VCDS more often... I did this change in VCP, which didn't have this info whoops!
    I'll test the other ones. I've also checked out 40, 50, 60, but without any results.
    And yes.. it's winter on this side of the world. I hope spring comes soon!
  6. #776
    Mar 2016
    Slovenia
    Tnx for that. I now understand why not working. I see in ETKA that this man sell me the wrong mirrors, without folding i now order the new one.
    What can i do with rain closing ? I have make all your procedure from page 24, but not working
  7. #777
    Feb 2016
    Oslo
    I have some strange sound from my speakers when I enter the car. The sound is coming regardless of ignition on/off. Sounds like an identification "whoosh" which lasts for just a second but it's bothering me. This happened after installing a sound system. Is there anywhere in VCDS I can modify the sound system settings? I have been reading on the topic for a MK6 and there you have description and help in the long coding but not for MK7... Has anyone experienced this and any suggests for a fix?
    Thanks all
    Just an update to this: I found out that it happens when Discover Pro is shutting down. This happens when I don't turn on the ignition after I go inside. As the Discover Pro is starting when I open the door, although the screen remain dark, it stays on for a while. So now my question is slightly different: Anyone else noticing some strange sound output in the speakers when the device is shutting down?
    2016 MK7 Golf GTE
  8. #778
    VCDS Tweak: Tail-light illumination when hatch open - Safety feature
    I was recently acquainted with this tweak by a newbie forum member (thanks harisg). The tweak will illuminate the outer tail-lights (left & right) whenever the hatch is opened. This illumination happens regardless of the position of the rotary light switch, or the time-of-day (i.e. irrespective of whether the car has a RLS/RLHS/RLHS installed, or not). To the extent that the additional illumination provides a "visual" warning for approaching vehicles that a person is at the rear of the car, the tweak is considered a safety feature worthy of implementation.
    The tweak is straight-forward and easy to implement, but I have purposefully complicated these instructions to cater of our growing number of USA forum colleagues. As you may be aware, NAR (North American Region) cars have a slightly different lighting arrangement and the factory Leuchte settings for their outer tail-lights are more-functionally rich than our RoW (Rest-of-world)models - due in large part to the fact that the outer tail-lights must also perform the standard blinker activity
    A final point - once implemented this tweak will override the normal rear brake-light function. So if you drive with the tailgate opened, the tweak may not be appropriate!
    1. Select 09 - Central Electr control module
    2. Select Security Access - 16 from the "Open Controller" screen
    3. Enter the magic number 31347 and return to the "Open Controller" screen
    4. Select Adaptation - 10 from the "Open Controller" screen
    5. From the pull-down button check that the default settings for the adaptation channels shown in the table below for either your RoW or NAR vehicle are as indicated in the RoW/NAR Setting column
    6. For the car type (i.e. RoW, or NAR), change the adaptation channels depicted in the table below to the values in the New Setting column (use the "Search" box to locate the correct channels)
    Notes:
    1. I've shown the complete Leuchte-set for both outer tail-lights for completeness, For confirmation though:
    • If the car is RoW:
    (5)-Leuchte21BR RC8-Lichtfunktion B 21 and
    (5)-Leuchte20BR LA71-Lichtfunktion B 20
    need to be changed
    • If the car is NAR,
    (16)-Leuchte21BR RC8-Lichtfunktion G 21, and
    (18 )-Leuchte21BR RC8-Dimmwert GH 21, and
    (16)-Leuchte20BR LA71-Lichtfunktion G 20, and
    (18 )-Leuchte20BR LA71-Dimmwert GH 20
    need to be changed
    2. If the default factory settings in the car are not as shown in the table- do not proceed with the tweak
  9. #779
    Jan 2007
    Monkeyland
    Been digging around again on the idea DCC voltage could be modified for the different driving modes. Still have not found where the mode selections can be modified although you as Don suspected i can see the damper voltage. It does change if i bounce up and down in the car as the DCC system should. More tinkering to come as i get free time.
    VCDS (VAG-COM) codes and programmable options for Golf Mk7-susp1-jpg
    Also, when activating the offroad screen i see the 'sport' info that could be modified. Anyone tinkered with these???
    VCDS (VAG-COM) codes and programmable options for Golf Mk7-sport1-jpg
  10. #780
    Quote Originally Posted by monkeysrus View Post
    Monkeysrus: Without wishing to be pedantic, I think for your exercise, you should make a distinction between "Voltage" and "current". The two are of course related by Mr Ohm's law, but in the DCC application, I think that latter is the correct characteristic.
    My understanding of the operation of the shocker in a DCC system is that it operates an electro-mechanical "plunger" which is inserted in the outlet valve for the oil chamber. The oil flow exiting the shocker's central chamber when it is compressed must work against the force of the electro mechanical plunger which acts like a pre-tensioning device.
    The force of the plunger in restricting the flow of oil in the shocker chamber can be adjusted by varying the electrical current (not voltage) to the coil (i.e. the moving core of the plunder sets the pre-tensioning force in the valve by varying the size of gap through which the oil must flow to exit the shocker chamber)
    My understanding is that the range of supplied current to the coil is 250 milliamps (1/4 Amp) to 2 Amps. Towards the upper end of this range, the pre-tensioning force is increased and the ride becomes "harder" (sports mode) and the opposite happens at the 250 milliamp end which is "soft" mode. Normal (I guess) would be in the centre of the range.
    What this means (I guess) is that the adaptation channels in your previous admap establishes a different pre-tensioning starting point. The higher you make the settings, the "stiffer" the ride - I guess. Not sure if you can select a negative current value to "soften" the ride
