Page 73 of 198 FirstFirst ... 2363717273747583123173 ... LastLast
Results 721 to 730 of 1974
  1. #721
    Quote Originally Posted by zloybob View Post
    Do u have skype or whatsapp? Pm me) its selfmade "zdc"
    Files ZDC absolutely personal and not transferable.
    OK PM
    Thanks!!
  2. #722
    Feb 2016
    Oslo
    Lightbulb Low beams on during daylight
    Hi guys. I have been struggling to find out how to set my low beams to stay active during daylight on my GTE. I don't want the DRL lights so I need the low beam to stay on at all times on my car. I have tried the following:
    09-Central Electronics > Adaptation-10
    (5)-Leuchte6ABL LC5-Lichtfunktion B 6
    Value: Daytime running lights
    Stock: Lichthupe generell
    (6)-Leuchte7ABL RB1-Lichtfunktion B 7
    Since I don't know what "Lichthupe generell" does I replaced it with Daytime running lights. I did this during daylight to see the difference and it was working all fine. The issue happened the next day, when I checked I had no low beams, they were only working when it was dark. So I guess there is an issue with the dimming (I read "Lichthupe generell" had something to do with dimming).
    I know I can control this from the switch, but I like to have mine in "Auto" position because the car is equipped with the high beam assistant.
    Can anyone please help me with this?
    Thanks in advance
    2016 MK7 Golf GTE
  3. #723
    Quote Originally Posted by Drive View Post
    Thanks in advance
    Drive: Hello. It seems odd to want to have the low beams continuously turned-on, but I have to admit, that my knowledge of the day-time environment in Oslo is very poor!
    Anyhow, my suggestion is that you return the changes that you made back to the original settings ( see values below) and try the changes in my table below. Please note that there are changes required to channels (8 ) and (10) in the left and right lamps. Also note that I have not tested these changes - please provide feedback when (if) you try them.
  4. #724
    Feb 2016
    Oslo
    Cheers Don! What is bugging me is the crappy light sensor which is oversensitive. It goes nuts at times. I can see that on the navigation screen that it switches back and forth between day and night mode. Also I gotta admit that I'm slightly tired of the e-Golf look as we have sooo many in Norway...
    I have already made the changes and I'm looking forward to see how it works. In the meantime I came across the following setting:
    ( 8 )-Daytime running lights-Fahrlicht bei Tag,Daytime running lights
    I'm not sure what kind of options I have on this one but maybe I can solve the puzzle with this one setting.
    Thanks a lot for your help
    2016 MK7 Golf GTE
  5. #725
    Drive: Yes, changing the setting for ( 8 )-Daytime running lights-Fahrlicht bei Tag,Daytime running lights from "daytime running lights" to "low beam" will work, but it will disable the normal DRLs (i.e. this channel is either/or). I had assumed that you want to keep the normal DRLs illuminated AS WELL AS the low beams
    PS: In respect of your "crappy light sensor", you could check the coding on the RLS/RLHS/RHFS (which is a slave module to the BCM). The pertinent Byte is hex0 (see picture below) - is your coding for Bits 3-5 hex00? You could also check the setting in the MENU for turn-on threshold
  6. #726
    Feb 2016
    Oslo
    Yes I want to disable the DRLs totally and just use the low beam so I will assume this simple setting will work. Regarding the Light Activation Threshold, I need to check that. As you said there is an option in the MENU (Early-Medium-Late) so is this something in addition to that or are you basically toggling the same setting with this hex?
    Example: If I set mine to Early in the MENU, and set this one to +80% earlier, does that mean really really early?
    2016 MK7 Golf GTE
  7. #727
    Drive: OK. My assumption (about you wanting both DRLs and low-beam operating together) was predicated on your first post where added DRLs to the low-beams -without removing the DRL settings from the 2 x Leutche sets. But if you just want to substitute the Low beams, then the simpler tweak is better!
    As for your question about the RLS/RLHS/RLHS, the settings for Byte 0, Bits 3-5 are stand-alone and are not affected by the value in the MENU. The way I think about this facility is that settings in Bits3-5 create the reference threshold around which the MENU values operate. So, the absolute latest light threshold is Bits 3-5 set to Hex00 and the Menu value set at "late", and the absolute earliest light threshold is Bits 3-5 set to hex20 and the Menu value set at "early" (hope this makes sense)
  8. #728
    Feb 2016
    Oslo
    Don: I wanted to confirm that this does not work. Low beams won't turn on during day in Auto.
    2016 MK7 Golf GTE
  9. #729
    Drive: thanks for the feedback. If I had HIDs on my mk7, I would try some alternative remedies, but since you have an alternative method, I'll leave it
  10. #730
    VCDS (VAG-COM) codes and programmable options for Golf Mk7
    UPDATE TUTORIAL MODS VW GOLF MKVII v.1.3
    In Spanish!!
    News v.1.3 :
    Link Updated - > PDF DOSSIERS MODIFICACIONES PARA VW GOLF MKVII
    https://goo.gl/D37qgp
    Versión v.1.3 18-02-2016
    Size + 111MB
    Numbers of pages 216
    Controller Channel Map (Mapas de Adaptación) y Auto-Scan en varias versiones de Vag-Com en el VW GOLF's MKVII de @XaGiCo y @Algagu
    New Data 10 , 65 y VAGCOM 15.7.3
    Link Updated
    NeXT Toturial Park Assist Retrofit sin e Park Pilot ....
    Link Club VW Golf España -> VCDS/VCP MKVII
    http://www.clubvwgolf.com/foro/showt...=1#post3189838
    Enjoy It!!VCDS (VAG-COM) codes and programmable options for Golf Mk7VCDS (VAG-COM) codes and programmable options for Golf Mk7VCDS (VAG-COM) codes and programmable options for Golf Mk7
    Good Day / Night!!
    Regards!!
    Club VW Golf España
    http://www.clubvwgolf.com/foro/forum.php
    XaGiCo
