Originally Posted by
monkeysrus
Query for all the people that know a lot more about VCDS than I do.
For cars with DCC would the damper values be able to be changed somewhere in the system??? There are obviously values stored so when you change between modes the voltage to the adjustment valve changes.
If you change the springs and they have a 10% higher spring rate if you could adjust the damper values up 10% it would assist controlling rebound. The compression stiffness would obviously be higher from both the spring rate and damper compression.
Details on how the system works here:
Volkswagen DCC Adaptive Chassis Control – Design and Function | my-gti.com
Monkeysrus: I don't have DCC, but I suspect that the answer lies in the suite of adaptation channels for J250 (which resides at address hex14 on a mk7). Here is an admap for J250 from my database for an RoW vehicle:
Code:
;SW:5Q0-907-376 HW:5Q0-907-376 --- Susp. Elect.
;Component:DAEMPFUNGS-SG H15 0115, Coding:
;EV_DRCONTITEMIC,001019,EV_DRCONTITEMIC.rod
;Thursday,16,January,2014,07:51:44:64864
;VCDS Version: Release 12.12.0 (x64) Data version: 20130910
;VCID: F6E89DA5493ADDAE3EF-80A3
(1)-Adapting with deflected wheels-Left front level ctrl sys sensor; adaptation value (deflected),67.09 %
(2)-Adapting with deflected wheels-Right front level ctrl sys sensor; adaptation value (deflected),35.86 %
(3)-Adapting with deflected wheels-Left rear level ctrl sys sensor; adaptation value (deflected),68.00 %
(4)-Adapting with deflected wheels-Right rear level ctrl sys sensor; adaptation value (deflected),33.00 %
Channel selection,1
(1)-Chassis data-1,0
(2)-Chassis data-2,0
(3)-Chassis data-3,0
(4)-Chassis data-4,0
(5)-Chassis data-5,0
(6)-Chassis data-6,0
(7)-Chassis data-7,0
(8)-Chassis data-8,0
(9)-Chassis data-9,0
(10)-Chassis data-10,0
(11)-Chassis data-11,0
(12)-Chassis data-12,0
(13)-Chassis data-13,0
(14)-Chassis data-14,0
(15)-Chassis data-15,0
(16)-Chassis data-16,0
(1)-Constant current loading mode-Constant current loading mode; activation,OFF
(2)-Constant current loading mode-Constant current loading mode; left front,0 mA
(3)-Constant current loading mode-Constant current loading mode; right front,0 mA
(4)-Constant current loading mode-Constant current loading mode; left rear,0 mA
(5)-Constant current loading mode-Constant current loading mode; right rear,0 mA
Roller test bench mode; functional,not activated
If you have DCC on your car, you might consider "intelligent experimentation". Hope that you don't need a security code
