Originally Posted by
agentthumb
Answered my own question. Halving the X5 value in Don's spreadsheet has done the trick, so it would appear. Time will tell.
Also Don, not sure if you are aware, but I think the photo transistor is actually on the side with the Tacho, not in the middle under the MFD as per your literature. I have attached a photo, it's the round thing next to the high beam indicator.
It is the only area that responded to my focused spot light.
Agentthumb: Sorry that I couldn't get to you sooner, but I'm glad that you sorted-out your problem.
Had I responded sooner, I would have suggested that you download my macro spread-sheet and try different lighting curves HERE.
The X5 value is certainly the fixing-point for the greatest daylight illumination, but you might find that the cluster illumination needs a tweak at lower ambient light levels. It's a bit of a compromise really between increasing the illumination on the cluster and not having the other phototransistor controlled items too bright. You could of course also tweak these other curves, if you have the interest.
But if you are happy with my tweak curve, then there's nothing more to do (mercifully)
PS Thanks for the location of the phototransistor - I think you are correct - that looks like the spot
