Originally Posted by
jonoz
Not sure if this is the right place but randomly the auto open/close on the drivers side window does not function, where you press the button down and the window winds the whole way down?
I made some VCDS tweaks, like auto rain closing etc, just wondering if there is a way to reset everything to defaults to check nothing is messing with the window auto close/open?
Jonoz: Hi.
Intermittent faults are a bitch to find and fix, but you might try the following:
1. Check if convenience opening and closing is set correctly
- Press the CAR button on the RH side of the Discover media Unit
- Press the set-up panel on the bottom RH side of the screen
- Press the Opening and Closing panel
- Make sure that the settings for Convenience opening option is set to All windows
- Exit the screen
2. Check the codinglog.txt file on your laptop. This will enable you to validate the VCDS tweak changes that you have already (please don't be offended-I'm not suggesting that they were incorrectly made). If you are not aware of how to do this, I wrote a short primer on the process which you can find HERE
3. Reset
As for your question about how to reset everything, you can reset the MENU functions in the car using the following process:
- Select Factory Setting panel (it's the very last entry on the list)
- On the Factory Setting screen, select Reset all Settings
- Press the Reset panel
However, If your question was about how to reset the tweak changes that you previously made, you can use the information in the Codinglog.txt file to roll-back any modified coding, or adaptation channels.
Cheers and good luck
PS: As I write in my paper, the codinglog.txt file can be a bit confusing if you have made lots of changes. If you post-up a copy where it can be downloaded, I'm sure that someone here will parse the data for you so that it is more readable
