Golf VII: Hi, I had the same niggling concern when I first saw the "poor oil quality" setting in the adaptation channel. But then I read VW's material about servicing and my concern was assuaged! This is how I understand it - there are apparently two types of service interval types used by VW; the normal Fixed Service Interval (FSI) and Extended Service Interval" (ESI). The adaptation channels are grouped for the two types in my earlier post.
ESI apparently will permit service intervals of up to 50,000 kms and/or two years, but to enable this facility, the car needs to have some extra smarts. To find-out whether your car has ESI capabilities you need to look for the PR code QGI on the vehicle data carrier sticker (see below)
Cars with this PR number have ability to make a special calculation of the oil condition based on oil temperature, oil level, elapsed time and also brake pad wear (and battery condition as well - I think). For cars that are capable of ESI, I understand that the entry in the adaptation channel that you made comment-on is an input the oil condition calculation (note that the begining of the descriptor for this channel is "ESI"). But this setting is not accessed for FSI because the only two determinants of when the next oil change is needed is distance travelled and elapsed time
So even if you change the setting on this channel, I'm fairly certain that not much (if anything) will happen. I've just left mine as-is because whilst the my car can measure stuff like oil temperature and brake pad wear, it doesn't have the special PR code and it can't do the oil condition calculation
PS: I'm not sure if ESI can be enabled with a VCDS cable (i.e. if the oil condition calculation is native to the mk7's software and it's just a matter of turning it on). Any comments from others in this regard would be welcomed
