Jazrod: Hi.
My apology, but I'm not sure that I understand what your saying. Are you asserting that your existing
(9)-Leuchte12NL LB45-Lichtfunktion D 12 channel has a current value of "0" ( instead of "not active"), or are you saying that
(10)-Leuchte12NL LB45-Dimmwert CD 12 has a value of "0". If you are referring to channel (10), then this is the value that it is meant to have (before you change it to 127 - because you have LED Fogs).
You haven't said what model car that you have, but I have included below a table of the default values for 4 x Golf mk7 vehicles. As you can see they all have the same default values, so I'm confident that my table is correct. Plus I have actually implemented this tweak my self on the 103TSI - so I know that the table is correct!
Don't take this the wrong way, but it's very easy to confuse these channels because they all look alike and because there are 655 Leutche channels in a mk7. As I say in my tweak instructions, "Leutche" programming is very easy to get wrong (again, I'm not insinuating that you have made an error).
Are you able to post a screen shot of the problem channels so I (and others) can have a look at them. If you are not able to do this, can you accurately copy the channel names and their default settings on a post here? My other suggestion is that you post up your CodingLog.txt file on a third party site and copy the link here. It will tell me what changes that you have tried to make - even if they were unsuccessful.
As for your other question (about Fogs and high beam activated together), the answer is that I can make some suggestions for you to try- if you want. But I think that we need to solve your "flasher" problem first.
