Those that haven't yet looked at the Body Control Module on a mk7 Golf might be surprised to learn that the 09-Cent. Elect. module devotes a total of 665 separate adaptation channels entirely to the management of the car's exterior lighting. Fact is that control of the exterior lights on MQB platform vehicles is comparatively sophisticated and each of the car's exterior lights can be separately programmed in a variety of ways. This makes it possible to customise the behaviour of these lights to suit each owner's personal taste. There is a growing understanding in the world outside VW generally, and in non-German speaking countries in particular of what I'm calling "Leutche" programming. With this new-found knowledge a new flurry of lighting tweaks will doubtless appear in the near future.
A simple example of this is the following tweak which enables fog-lights to be operated together with high-beam lights.
The cable user can choose either, or both of the following options:Option 1: fog-lights are turned-on with high-beam lights when the left-hand stalk behind the steering wheel is pushed towards the windscreen (and the rotary light switch is in "Auto", or "On" position)- i.e. the normal high-beam switch on/off process
Option 2: fog-lights are "flashed" together with high-beam lights when the left-hand stalk behind the steering wheel is momentarily pulled towards the driver .
I developed this tweak by modifying a set of instructions that I first found on a German MotorBlog site (thanks TBAx) and following a suggestion that was made on this forum (thanks jazrod). I've tested this tweak (both options) on my own 103TSI mk7 Golf, so I can vouch that it works!
A word of warning for those that wish to implement this tweak. "Idle" (a forum colleague) has correctly advised that in some areas it may be a legal offence to operate fog lights when there is no actual fog. Consideration should be given to this matter before proceeding.
VCDS Tweak - Fog-lights operated with high-beam lights
- From the main screen select 09-Cent. Elect
- When the BMC screen opens, select Security Access-16
- Enter the magic number 31347
- When the main BCM screen returns, select Adaptation-10
- Change the settings in adaptation channels shown in the two Tables below to the "New Value":
Left Fog-Light
Adaptation Channel |
Old Value |
New Value |
Choose either, or both Options |
(8 )-Leuchte12NL LB45-Lichtfunktion C 12 |
not active |
Left high beam |
Change to implement Option 1 above |
(9)-Leuchte12NL LB45-Lichtfunktion D 12 |
not active |
Lichthupe generell |
Change to implement Option 2 above |
(10)-Leuchte12NL LB45-Dimmwert CD 12 |
0 |
100 |
(11)-Leuchte12NL LB45-Dimming Direction CD 12 |
maximize |
maximize |
Right Fog-Light
Old Value |
New Value |
(8 )-Leuchte13NL RB5-Lichtfunktion C 13 |
not active |
Right high beam |
(9)-Leuchte13NL RB5-Lichtfunktion D 13 |
not active |
(10)-Leuchte13NL RB5-Dimmwert CD 13 |
0 |
100 |
(11)-Leuchte13NL RB5-Dimming Direction CD 13 |
maximize |
maximize |
Notes
Note 1: The channels in the Tables above are about 70% down the list of channels on the VCDS adaptation screen
Note 2: Select the adaptation channels carefully as other channels have similar descriptions
Note 3: If the adaptation channels in the car do not have the "Old Value" indicated in the tables do not proceed with this tweak
Note 4: If LED fog-lights are installed, change adaptation channel (10) on both left and right fog-lights to 127 (instead of "100")
Note 5: Adaptation channels (11) (i.e. last row in the two Tables) should not need to be changed, but the settings should be checked |
