I haven't been able to get it to work, and in fact the convenience opening is not working since I tried the tweak. What car do you have, as I would be interested in seeing your adaption settings to see if mine are different to yours, in particular these settings:
(1)-Access control 2-Komfortbedienung global |
(2)-Access control 2-Comfort opening |
(3)-Access control 2-Comfort closing |
(6)-Access control 2-Funk Komfort schliessen |
(7)-Access control 2-Funk Komfort oeffnen |
(19)-Access control 2-Kessy Komfort oeffnen |
(20)-Access control 2-Kessy Komfort schliessen |
I believe my issues started when I tried recoding the code for auto rain in the coding section of cent elec with the beat version. Prior to this, although I had menu settings for turning the rain tweak on, out did not work. As DV52 pointed out, one of the reasons may have been that the 12.12 software version of VCDS did not allow the coding change, which appeared to be one of the tweaks that needed to happen on other models of VW.
DV52:
I've tried putting those unusual setting back to what I believe to be the original which incidentally coincided to what you thought, and have replied to your email. I came up with pretty much the same "original" stuff as you, but still with no joy. For others following this thread, I have also looked to see if fuses were blown but there does not appear to be a fuse for "convenience opening", and the fuse for the sunroof is obviously working as the sunroof opens and closes normally.
I wonder if it is possible to do a "hard reset" of the ECU as I am tending to think it is something in there that is corrupted.
Cheers.
