Page 13 of 198 FirstFirst ... 311121314152363113 ... LastLast
Results 121 to 130 of 1974
  1. #121
    Quote Originally Posted by andrew7 View Post
    Here is the Soundakator mod screen shot
    andrew7: Are the instructions for the VCDS tweak as follows?:
    To Mute Soundakator
    1. A9 Structure Borne Sound
    2. Adaptation 10
    3. At Channel drop down choose "Volume of structure borne noiseactuator" (only choice)
    4. Enter a value in the proper box (0% = mute)
  2. #122
    May 2014
    Russia
    Zloybob: Russia huh? wow this forum sure does get-about!
    I've taken a screen shot below of the Hecadecimal coding string for block 5F (Information Elec. control module) on my car (which has TMC activated). Is this what you are after?
    =) thanks, this what I was looking
  3. #123
    Central VIC
    To Mute Soundakator
    2. Adaptation 10
    ^ Correct Don.
    This is what I copied off another UK forum:
    OK, here it is (courtesy of Golf mk7 FORUM):
    Go to:
    - A9 Struct. Borne Sound
    - Adapation 10
    - Select "channel of structure borne sound " (only choice)
    - Std value 100% - change to the value you want stored in % (60% has been suggested as a good happy medium, adjust to 0% if you want no noise/mini vibrations).
    - "Use change code for change approval"
    As above, I am planning on setting volume at 60% which from others who have done this appears a happy compromise (0% would of course = mute)
  4. #124
    Quote Originally Posted by readerr0r View Post
    Sorry man, Australian Golfs don't get the Discover Pro, only some Skodas do so I don't think anyone would know?
    readerr0r: It's always good when I don't know stuff because I learn something new! Zloybob didn't answer my question about how the long coding string from my car could be used for his Discover Pro screen. I would have thought that a byte-by-byte comparison of the coding for the two MMIs would be unworkable. Any ideas ?
  5. #125
    Aug 2011
    Very likely, usually the units come from different brands so there's slight differences between exact coding. I haven't had a chance to do much with Golf 7/Octavia 3 coding yet so I don't have in-depth knowledge. Getting SUNA working on the Octavia's Discover Pro is on my personal to-do though.
    Plus the other Octavia coding bits and bobs, laptimer, show speed limit on the colour MFD, DRL off on indicate etc.
  6. #126
    Apr 2010
    Just a shame that there is nowhere to type 1024 into in VCDS for the RNS510 (I looked)
  7. #127
    Aug 2011
    The map disc has the tmc info on it. You'd have to copy the TMC folder from europe disc, figure out where it stores the key and then somehow get it to associate that with the AU map.
  8. #128
    Apr 2010
    Sounds doable
    btw when digging around the RNS510 in VCDS I saw a setting described as 'Eject Lock' -wonder if that has anything to do with some of those guys who couldn't eject firmware CDs after botched update attempts.
  9. #129
    Ryan_R:I have zero understanding of the RNS510, but the (now) famous "1024" is equivalent to hexadecimal "400". VCDS seems to use base-16 units a lot. As an uninformed question is there anywhere to add this value?
  10. #130
    Apr 2010
    There are plenty of places where you can type it
