See here
Hi. I'm very new to the whole VCDS coding stuff. How ever I'm keen to have a go with some research. But I don't know what I need to do it. Could someone please tell me what software, cables, information locations, ect is needed to start VCDS coding??? I have not idea what to buy/download.
2014 VW Golf TDI Highline DSG - Limestone Green, DAP, Xenons
2018 VW Golf R Hatch DSG - White Silver, DAP , Dynaudio
2016 Skoda Superb 140TDI - Family Members
2013 VW Amarok TDI420 Highline Auto - Family Members
Thanks for the link Ryan_R. Is the information much the same for the mk7?
The concepts, tools, and software are all the same. The actual coding references will be different and are pending research + documentation (this thread).
Hi all
I just downloaded the latest software from Ross Tech (ver 12.2.2) - I also loaded the Beta SW (ver 14.2). I was interested to see what further support VCDS had for the Golf Mk7 given that the now obsolete SW ver 12.12.0 had lots of controllers with no labels.
Anyhow, the table below summarises controller support for the 103 TSI Golf (i.e a bog-standard highline) from the three SW versions. Guess that it is disappointing that there are still two missing labels in the latest SW version, but at least the number has fallen! Also dissappointing is the amount of German language that still pervades many of the pull-down channels. Not sure if support for the mkVI Golf was plagued with similar issues when the model was in its infancy.
Golf MkVII 103TSI Address Controller Labels - Ver 12.12.2
(& Beta 14.2)Labels- Ver 12.12.0 Address 01: Engine (J623-CHPA) 04E-907-309-V1.clb 04E-907-309-V1.clb Address 02: Auto Trans (J743) 0CW-927-769.clb 0CW-927-769.clb Address 03: ABS Brakes (J104) 5Q0-907-379.clb 5Q0-907-379.clb Address 08: Auto HVAC (J255) 5G0-907-044.clb 5G0-907-044.clb Address 09: Cent. Elect. (J519) 5Q0-937-08X-MV1.clb 5Q0-937-08X-MV1.clb Address 10: Park/Steer Assist (J791) 5Q0-919-294.clb 5Q0-919-294.clb Address 15: Airbags (J234) 5Q0-959-655.clb 5Q0-959-655.clb Address 16: Steering wheel (J527) 5Q0-953-549.clb 5Q0-953-549.clb Address 17: Instruments (J285) 5G0-920-XXX-17.clb None Address 19: CAN Gateway (J533) None None Address 42: Door Elect, Driver (J386) 5QX-959-X93-42.clb None Address 44: Steering Assist (J500) 5Q0-909-144.clb 5Q0-909-144.clb Address 52: Door Elect, Pass. (J387) 5QX-959-X92-52.clb None Address 5F: Information Electr. (J794) None None
Hello DV52,
Can you tell me where you obtained the module information in your post.
Thanks.
Bloggo: Not sure if I have understood your question correctly, but the underlying information from my table comes from a comparison of the autoscan reports for version 12.12.0 & version 12.12.2 software.
For eample, I enclose below a bit of the autoscan report for my car from Ver 12.12.0 software. This section of the report shows the data for the first controller.-------------------------------------------------------------------------------
Address 01: Engine (J623-CHPA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 G HW: 04E 907 309 A
Component: 1.4l R4 TSI H08 5272
Revision: WAH08---
Coding: 01250032242405082000
Shop #: WSC 00028 028 00079
ASAM Dataset: EV_ECM14TFS01104E906016G 002006
ROD: EV_ECM14TFS01104E906016G_VW37.rod
VCID: 26431A2059EACC2ECEF-8073
No fault code found.
Readiness: 0000 0000
I have high-lighted in bold the hexadecimal address and the label identifier of the controller in this example. I tabularised this data for each of the controllers in the two separate autoscan reports into a simple excel spreadsheet. There is nothing particularly intelligent about what I did, but it helps provide (me and others, I hope) a visual comparison of the two SW versions. My purpose in creating the table was to see what advancement Mr Ross had made in the latest software version to support the MkVII platform.
I admit that my exercise may be viewed by some as the failing of a pedant, but forums such as this are full of different folks with different motivations. This is what makes VWW such a fascinating site! Anyway, apart from this psychological aside, I hope that I have answered your question. Please re-ask your question in another way if I have misinterpreted your needs.
See the following post from DV52 for instructions on disabling DRLs via VCDS:
Turning off Daytime running lights
Can anyone tell me what a "High Traction Dropdown" is? Apparently I have more than one installed in my mk7 Golf. I know this because the VCDS screen below says that I have at least two of these things, The screen shot came from the latest Beta SW version for the Central Electronics controller (byte 2 - see bit 3 is enabled).
I've tried researching this on the web, but I just get vague references to something that "raised the back end of KITT so that Michael could drive the car over more uneven terrain" (i.e. in the fabled knight-rider car). This can't be right on a mkVII - whilst this would be real cool accessory, I'm pretty sure that VW would have charged me extra for the option of dynamically lifting the rear end of the car over rough roads.
I've learn't from another thread that the development team at Rosstech has quite a sense of humor, so perhaps this is another example of thier whitty antics - ain't nothing wrong with that! Any advice welcomed.
