Page 98 of 198 FirstFirst ... 488896979899100108148 ... LastLast
Results 971 to 980 of 1974
  1. #971
    Jun 2016
    N/A
    ringo: hi. The short answer is YES, but if you specifically want ONLY the DRL to be activated as the CH/LH lights, then you will need to make changes to a few "Leuchte" channels in the BCM.
    However, if your objective is to NOT USE the low beam lamps for this function, then a simpler alternative (from a tweak perspective) is to have the fog-lights operate when CH/LH is activated (I think).
    If this alternative is acceptable, then this is the fix:
    1. Select the BCM
    2. Select security access and enter the magic number 31347
    3. Select adaptation and type "ENG115656" into the search-box
    4. Select the adaptation channel IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten from the drop-down box
    5. Change setting from Low beam to Fog light
    6. Press Doit!
    7. Exit software
    Hi Don,
    A great answer as always! However given that it's a Clubsport there are no fog lights to use so I presume the suggested alternative is not possible in my car and I do have to mess with the Leuchte channels indeed? Is there any other way to have only DRL's on for CH/LH? Probably not as you would have suggested it already...
  2. #972
    Quote Originally Posted by ringo View Post
    Hi Don,
    Ringo: My bad- I wasn't aware that you had a Clubsport mk7 or its options (strange that your car has the sophistication of HIDs and the leveling mechanism, but it doesn't have fogs- but then the boffins at VW do some strange things).
    Anyhow - instead of me suggesting an answer, I have borrowed the instructions from the tweak
    For ease of reference, I enclose the table below which is taken from the link:
    Instructions: DRL only for Coming Home/Leaving Home (without Low-beam lamps)
    1. Select 09 - Central Elect. control module
    2. Select Security Access - 16 from the "Open Controller" screen
    3. Enter the magic number 31347 and return to the "Open Controller" screen
    4. Select Adaptation - 10 from the "Open Controller" screen
    5. From the pull-down button check that the default values for the adaptation channels are as shown in the table below for the OLD SETTING column (use the "Search" box to locate the correct channels)
    6. Only if the check in (5) above is successful, change the values for the adaptation channels as depicted in the table below in the NEW SETTING column (use the "Search" box to locate the correct channels)
    The tweak instructions are for a North-American-Region vehicle (not our Rest-of-Word model), but this doesn't matter. Simply use the LAMP column to select which lights you want to alter. For example, you can elect to retain the center-dots involvement in CH/LH function by not making changes to Leuchte4FL LB4 and Leuchte5FL RB32 channels - it's entirely your choice!
    It's of course an untested tweak, but my reading of the instructions is that they appear to be compatible with your request.
    Good luck and please provide feedback if you try the tweak - that's how the forum community in general (and me in particular) learns stuff!
  3. #973
    Jan 2012
    I am now officially a pace car, please stay behind me! Thanks again for all the info on tweaks in this forum. Love the VAG! Keep up the good work.
    2015 Golf R. Lapiz Blue.
  4. #974
    Jun 2016
    N/A
    Anyhow - instead of me suggesting an answer, I have borrowed the instructions from the tweak HERE
    The tweak instructions are for a North-American-Region vehicle (not our Rest-of-Word model), but this doesn't matter. Simply use the LAMP column to select which lights you want to alter. For example, you can elect to retain the center-dots involvement in CH/LH function by not making changes to Leuchte9FL RB2 and Leuchte8FL LB39 channels - it's entirely your choice!
    Wow that's a serious tweak! I'll try to find the time and do it over the coming days and report back.
    The fog lights get deleted on the Clubsport because of the aerodynamic design of the front bumper. Where the standard GTI has fog lights, the Clubsport has these so called air curtains that divert the air around the front wheels. That doesn't mean there are no boffins in general in VW...
    Personally I quite like it as its both a sportier look and I hate it when different types of lights (with different color temp) are installed at the front or rear of any car, it almost looks aftermarket to me. And I doubt fog lights would offer any extra benefit than the DRL's already do under foggy conditions.
  5. #975
    Jun 2016
    N/A
    Ok, so I tried it yesterday. I basically only messed with the first two low beam channels Leuchte6ABL and 7ABL (the dot LED and U leds were already part of the CH/LH function and I wanted it to stay that way). Worked as expected: Headlights now stay off every time I unlock the car, only the U and dot leds are illuminating, job done!
    Thanks Don!
  6. #976
    Nov 2016
    Sweden
    Parking light in 3rd break light
    Parkinglight in 3rd Brakelight
    (16)Leuchte22BR M57-Lichtfunktion G22 > not active > Standlicht allgemein (Schlusslicht Positionslicht)
    (17 )Leucht322BR M57-Dimmwert GH22 > 0 > 1
    https://www.youtube.com/watch?v=6qBReJktx9Q
    I've always found the 3rd brake light to be a much undervalued facility on a car. Truth is that on a mk7, it can be used to do all sorts of additional functions (other than just being a brake light). On my highline, the third brake light was factory fitted with an LED.
    Here's some options for how the role of the 3rd brake light can be expanded. I discovered these instructions as part of material that I received from a forum colleague (Many thanks - Morde), who resides in Germany and therefore has access to a richer information base than us English folk (and he understand the German language- which is a great attribute to have when trying to decipher VW's cryptic nomenclature)!
    Note: for the three tweaks shown below, the structure of the changes across the Leuchte-set channels (and the non-Leuchte set channels) are arranged so that each individual tweak is independent of the other options. Pick-and-choose whichever tweak that you like (or choose none!),
    I implemented all three options on my car this morning and I can vouch that they all work
    3rd/High-Mounted Brake Light Tweaks - Instructions
    1. Select 09 - Central Electr control module
    5. From the pull-down button check that the default settings for the adaptation channels shown in the table below are as indicated in the Standard setting column
    6. For the wanted options, change the adaptation channels depicted in the table below to the values in the appropriate column (tip: use the "Search" box to locate the channels)
  7. #977
    Nov 2016
    Sweden
    Us Standlicht über Discover Pro
    (8 ) Leuchte1BLK VRB20-Lichtefunktion C1 > not active > Fussramlicht
    (10)Leuchte1BLK VRB20-Dimmwert CD1 > 0 > 100
    (11)Leuchte1BLK VRB20-Dimming Direction CD1 Maximize
    (12)Leuchte1BLK VRB20-Lichtefunction E1 > not active > Innenlicht
    (13)Leuchte1BLK VRB20-Lichtefunction F1 > not active > Blinken rechts Dunkelphase
    (14)Leuchte1BLK VRB20-Dimmwert EF1 0
    (15)Leuchte1BLK VRB20-Dimming Direction EF1 > Maximize > Mininmize
    (16)Leuchte1BLK VRB20-Lichtfunktion G1 > not active > Blinken recht Hellphase
    (18 )Leuchte1BLK VRB20-Dimmwert GH1 > 0 > 100
    (19)Leuchte1BLK VRB20-Dimming Direction GH1 Maximize
    (8 ) Leuchte0BLK VLB36-Lichtefunktion C0 > not active > Fussramlicht
    (10)Leuchte0BLK VLB36-Dimmwert CD0 > 0 > 100
    (11)Leuchte0BLK VLB36-Dimming Direction CD0 Maximize
    (12)Leuchte0BLK VLB36-Lichtefunction E0 > not active > Innenlicht
    (13)Leuchte0BLK VLB36-Lichtefunction F0 > not active > Blinken rechts Dunkelphase
    (14)Leuchte0BLK VLB36-Dimmwert EF0 0
    (15)Leuchte0BLK VLB36-Dimming Direction EF0 > Maximize > Mininmize
    (16)Leuchte0BLK VLB36-Lichtfunktion G0 > not active > Blinken recht Hellphase
    (18 )Leuchte0BLK VLB36-Dimmwert GH0 > 0 > 100
    (19)Leuchte0BLK VLB36-Dimming Direction GH0 Maximize
    https://www.youtube.com/watch?v=vByEpepG1JM&t=195s
  8. #978
    Nov 2016
    Norway
    VW Golf MK7 taillight non LED conversion - NAR to ROW - amber turn light
    Hi folks
    This is my first “post” so hopefully it goes in the right thread..
    I have a 2015 E-Golf North American version (NAR) and want to replace the tail light with OEM EURO tail light – NOT LED to get amber turn signal. There are lots of writing on the net about LED conversion but I could not find exactly my problem.
    I used this link as guide:
    VWVortex.com - LED Taillight Wiring & Coding Thread (North American Golf/GTI)
    I have purchased EURO tail light - (outer left and outer right ROW version) and installed them onto the car - no changes to: inner left and inner right tail light.
    I only changed the cable pin configuration for the outer tail lights and programmed “leuchte” A71, C8 and C6
    My main problem after the conversion: when I hit the brake, both amber blinkers(A71&C act as a brake light.
    Here is what I did on left side:
    Stock outer tail light (NAR) cable has 3 cables/pins:
    1. Red (A71) in PIN 1 (combined brake/turn signal/ park…)
    2.GND in PIN 2
    3. C6 in PIN 4 – Red side marker LED
    I repinned the left & right cables to a new configuration to match the EURO outer tail light – non LED and changed values in VCDS
    New configuration:
    1. Red (A71) into PIN3 (amber turn signal) – programmed A71 as turn signal in VCDS
    2. GND stays in PIN 2
    3. C6 into PIN 1 to become brake and driving tail light. – (programmed C6 as brake light and park/running light)
    Idid the same changes for the right side (C
    So what is happening on the outer tails.
    1. Amber section of the Euro tail light works nice as a blinker(A71&C – as it should
    But when I hit the brake, both amber blinkers(A71&C lights up together with the red brake light in C6, so there is 2 “brake” lights in the outer tail light – one red and one amber.
    2. The red section (C6) have some issues also. Light comes on but blink and dies out when turning on the light switch on the dash. If I touch the brake – the red light (C6)will stay on – as they should and they work fine.
    (the reason can be two pcs W21W bulbs on the same line(C6) probably solved if I use LED 7440 instead.
    So to sum up:Light (A71 and C6) both show the brake light - but A71 is only programmed as turn signal - se coding underneath.
    The strange ting is this. The E-Golf has a ECO B-mode (regenerative braking) on the gear shifter.
    If the car is in B-Mode it will turn on the brake signal automatically if you lift the foot of the accelerator and when it does – the brake signals works perfect – no light in the amber section (A71) - just brake signal in C6 lamp - so the B-mode understand my programming and repinning of the cable/wires
    So everything is working perfect except when I hit the brake pedal.
    Is there a problem using Leuchte A71 as a turn signal only? Is A71 & C8 tied to the brake system? - I see other people has shown programming examples A71 & C8 as turn signal, but I do not know if they have had success.
    Any idea what I can do to solve the problem?
    My hope is to avoid wiring from dashboard/BCM to the tail or open up the hatch and take turnsignal from (C10)
    Appreciate if somebody can help.
    Here is the coding examples I used (found on the internet)
    Turn signal left
    (1)-Leuchte20BR LA71-Lasttyp 20 12-Blinkleuchten
    (4)-Leuchte20BR LA71-Lichtfunktion A 20 Blinken links Hellphase
    (5)-Leuchte20BR LA71-Lichtfunktion B 20 not active
    (6)-Leuchte20BR LA71-Dimmwert AB 20 100
    (7)-Leuchte20BR LA71-Lichtanstteuerung HD AB 20 Always
    (-Leuchte20BR LA71-Lichtfunktion C 20 not active
    (9)-Leuchte20BR LA71-Lichtfunktion D 20 not active
    (10)-Leuchte20BR LA71-Dimmwert CD 20 0
    (11)-Leuchte20BR LA71-Dimming Direction CD 20 maximize
    (12)-Leuchte20BR LA71-Lichtfunktion E 20 not active
    (13)-Leuchte20BR LA71-Lichtfunktion F 20 not active
    (14)-Leuchte20BR LA71-Dimmwert EF 20 0
    (15)-Leuchte20BR LA71-Dimming Direction EF 20 maximize
    (16)-Leuchte20BR LA71-Lichtfunktion G 20 not active
    (17)-Leuchte20BR LA71-Lichtfunktion H 20 not active
    (1-Leuchte20BR LA71-Dimmwert GH 20 0
    (19)-Leuchte20BR LA71-Dimming Direction GH 20 maximize
    Turn signal right
    (1)-Leuchte21BR RC8-Lasttyp 21 12-Blinkleuchten
    (4)-Leuchte21BR RC8-Lichtfunktion A 21 Blinken rechts Hellphase
    (5)-Leuchte21BR RC8-Lichtfunktion B 21 not active
    (6)-Leuchte21BR RC8-Dimmwert AB 21 100
    (7)-Leuchte21BR RC8-Lichtanstteuerung HD AB 21 Always
    (-Leuchte21BR RC8-Lichtfunktion C 21 not active
    (9)-Leuchte21BR RC8-Lichtfunktion D 21 not active
    (10)-Leuchte21BR RC8-Dimmwert CD 21 0
    (11)-Leuchte21BR RC8-Dimming Direction CD 21 maximize
    (12)-Leuchte21BR RC8-Lichtfunktion E 21 not active
    (13)-Leuchte21BR RC8-Lichtfunktion F 21 not active
    (14)-Leuchte21BR RC8-Dimmwert EF 21 0
    (15)-Leuchte21BR RC8-Dimming Direction EF 21 maximize
    (16)-Leuchte21BR RC8-Lichtfunktion G 21 not active
    (17)-Leuchte21BR RC8-Lichtfunktion H 21 not active
    (1-Leuchte21BR RC8-Dimmwert GH 21 0
    (19)-Leuchte21BR RC8-Dimming Direction GH 21 maximize
    This one I modified to c6 from LA72
    Brake lights/running lights
    (1)-Leuchte26NSL C6-Lasttyp 26 13 - Bremsleuchten
    (4)-Leuchte26NSL C6-Lichtfunktion A 26 Brake light
    (5)-Leuchte26NSL C6-Lichtfunktion B 26 not active
    (6)-Leuchte26NSL C6-Dimmwert AB 26 100
    (7)-Leuchte26NSL C6-Lichtansteuerung HD AB 26 Always
    (-Leuchte26NSL C6-Lichtfunktion C 26 Standlicht allgemein (Schulusslicht...)
    (9)-Leuchte26NSL C6-Lichtfunktion D 26 not active
    (10)-Leuchte26NSL C6-Dimmwert CD 26 28
    (11)-Leuchte26NSL C6-Dimming Direction CD 26 maximize
    (12)-Leuchte26NSL C6-Lichtfunktion E 26 not active
    (13)-Leuchte26NSL C6-Lichtfunktion F 26 not active
    (14)-Leuchte26NSL C6-Dimmwert EF 26 0
    (15)-Leuchte26NSL C6-Dimming Direction EF 26 maximize
    (16)-Leuchte26NSL C6-Lichtfunktion G 26 not active
    (17)-Leuchte26NSL C6-Lichtfunktion H 26 not active
    (1-Leuchte26NSL C6-Dimmwert GH 26 0
    (19)-Leuchte26NSL LA72-Dimming Direction GH 26 maximize
  9. #979
    HFL: Helo og velkommen til forumet!
    I've had a quick look through your Leuchte-sets and I don't believe that the continued operation of the brake function on the turn signal lamps is due to any of the settings for the Leuchte channels.
    Rather, I suspect that the solution lies in the code-string for the BCM (not in the adaptation channels in the BCM). However, I fear that VCDS will be of little help in solving this problem! Don't get me wrong, I think that VCDS is a most excellent tool, but (for some reason) there are many Byte/Bits in the long coding helper screens missing their function descriptions.
    Nevertheless, I can suggest a way forward - if you can get access to an OBDeleven dongle. Not sure if you are familiar with this device, but I wrote a explanation HERE which may be of interest.
    OBD11 handles "long coding" a little different to VCDS, but it appears to be more informative when identifying the function of Byte/Bts for control modules. Unfortunately though, the screens that OBD11 uses for the "long coding" descriptors, don't identify the Byte/Bit numbers (i.e. there are no "tick boxes" next to the Bits as per the long coding helper screens in VCDS).
    So - I suspect that the way to solve your problem is to disable the Btye/Bit that I have surrounded in the yellow box in the screen shot below, which is from the "long coding" part of OBD11. I suspect on your mk7, the entry for this Byte/Bit is Yes (on my RoW car, the entry is "No"). Alas, as you can see there is no Byte/Bit number on the picture to translate to the long-coding screens on VCDS!
    You might even consider buying an OBD11 device - they aren't that expensive!
    EDIT: Whilst I still think that the process outlined above is the proper way of fixing your problem - if you aren't able to access an OBD11 dongle, perhaps it might be possible to "neutralize" the boxed Byte/Bit setting in the screen-shot above?
    This is an entirely untested suggestion, but if you include the Leuchte command for the Brake-light into the 2 x Leuchte-sets for the blinkers and you attach a dimming level of zero to this command - perhaps this will counter the effect of the coding Byte/Bit. Not sure, but it's a simple change - so worth a try (I think)
    So - my alternative suggestion is to try this:
    Left-side Turn-signal Existing New
    (8 )-Leuchte20BR LA71-Lichtfunktion C 20 not active Bremslicht
    Right-side Turn-signal Existing New
    (8 )-Leuchte21BR RC8-Lichtfunktion C 21 not active Bremslicht
  10. #980
    Nov 2016
    Sweden
    Don do you have any ide about what the sideblinkers i the mirrors has for Leuchte number
