Page 92 of 198 FirstFirst ... 42829091929394102142192 ... LastLast
Results 911 to 920 of 1974
  1. #911
    Apr 2011
    I knew I over stepped that line...
    And thank you for all your help with all things VCDS...
  2. #912
    Sep 2016
    Sweden
    Hey!
    I have a question:
    You know when you lock your car with the remote, the hazard lights flashes one time and when you unlock it flashes twice.
    I am wondering if it's possible to make the single " lock flash " a bit longer, say 2seconds.
    Anyone know?
    The VCDS guru mr DV52 might have an idea?
  3. #913
    Quote Originally Posted by Sbuddz View Post
    Hey!
    I have a question:
    Anyone know?
    Sbuddz: Halla.
    First, thanks for the kind words, but there are many far more knowledgeable VCDS guru's here than me.......and to prove this, my response is - I don't know of a way of increasing the strobe time for the lock acknowledgement flash on the turn signals. Perhaps someone else here can advise how this is done.
    If you want to accentuate the lock-door function, perhaps you might consider adding an audible acknowledgement instead. I've written instruction for how to do this in the VCDS reference thread.
  4. #914
    Mar 2015
    Warner, QLD
    Hey!
    I have a question:
    Anyone know?
    Have a play with 09. Central Electric. Specifically, this channel:
    (4)-Acknowledgement signals-Optical feedback during locking
    Default value is "Decelerate", not sure what the possible values are as I'm at work. But change it and see what happens.
    On another note, discovered this channel:
    (6)-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte
    Appears to flash your third brake light to acknowledge door locking.
    Golf MK7 103TSI Highline Wagon | Limestone Grey | DAP2
    Golf MK7 110TDI Highline Hatchback | Tungsten Silver | DAP
  5. #915
    Sep 2016
    Sweden
    Hey guys!
    Thank you for your answers.
    DV52, I have already activated the aucoustic acknowledgement on my car, thanks to your eminent guidance.
    Agentthumb, I have tried this option as well but I really can't tell the difference between "decelerate" and the default one.
    i will look around some more in the central electric section but guess is that this is controlled via something else.
    if anyone has an idea please let me know
    / The dumb Swede
  6. #916
    Mar 2010
    perth, W.A
    its definitely the alarm siren beeping and not the horn when you activate the lock/unlock acoustic acknowledgment?
  7. #917
    Sep 2016
    Sweden
    Since I don't have alarm I'm sure it's the horn on my car
  8. #918
    Sep 2016
    Sweden
    Another question:
    DSG7 as I have in my 2016 Golf Estate 1.4 tsi.
    When you are in manual mode you can up shift or down shift with buttons on the steering wheel or on the gear leaver.
    I can understand that gearbox automatically downshifts for you even in manual mode to prevent the stalling if you forget to downshift yourself.
    So far so good.
    But is it possible to delete the "kick down" function via vcds?
    if I have the gearbox in manual, I want to deside when to shift down when I am accelerating.
    if you press hard on the accelerator pedal the gearbox shifts down one or two gears depending on engine rpm but I want to delete that function.
    is it possible?
    / Sweden
  9. #919
    Mar 2015
    Warner, QLD
    Another question:
    So far so good.
    is it possible?
    / Sweden
    There is a safety element to this. Generally when you have the car in manual mode and you mesh the accelerator peddle in the complete wrong gear, the car thinks you are in a panic mode to accelerate away from danger (train lines, intersection etc). Therefor, it kicks down into the right gear (in relation to your throttle position) to get you moving.
    Not to mention if it's dropping two cogs, you are probably lugging the engine, which is bad.
  10. #920
    Quote Originally Posted by lynx View Post
    THANX for the Welcome
    I will check with the VW dealer if it possible to reflash the MIB-II Infotainment system with "GTI / R" firmware.
    Checked with my dealer and he said as it won't match with model blabla.
    Sent from my SM-G935F using Tapatalk
    Gemini (Killed), Daihatsu Charade Sold, Peugeot 306 Convertible Sold , Peugeot 306 GTI 6 Sold
    Ford FIesta Sold, Evo 7 Sold , Evo 8MR Sold , Megane 250 RS Sold
    MK7R Lapiz Blue Sold
    MK7R White Current
