Page 77 of 198 FirstFirst ... 2767757677787987127177 ... LastLast
Results 761 to 770 of 1974
  1. #761
    May 2013
    the Netherlands
    Quote Originally Posted by zloybob View Post
    Yes, of course =)
    Hi zloybob,
    I've been breaking my brain on this 0388 firmware wlan thing... Would it help if we compared our long coding and adaption channels to see where our differences are? I'm sure it's an easy fix.
  2. #762
    Quote Originally Posted by Chillout View Post
    GTE/E-Golf graphic instead of default:
    Module 5F
    Long Coding
    Byte 2, value 70 instead of 00.
    I will mess some more with this byte. Previously, only byte 18 seemed to influence the specific type of car (GTI or standard).
    Chillout - great GIF!! Here's some other options that you might want to try!
    PS: Is it really that cold in the Netherlands!!
  3. #763
    Feb 2016
    Oslo
    Module 5F
    Long Coding
    Hey Chillout, e-manager and Hybrid disappears from the bottom menu after the modification?
    2016 MK7 Golf GTE
  4. #764
    Oct 2013
    Can't get the rain closing tweak to work...went thru DV52s guide and tried everything. Just does not work. Mines a my15 R. Other tweaks have worked fine. Very frustrating. Any advice?
  5. #765
    Aug 2015
    Quote Originally Posted by jazzyjames999 View Post
    From what I've read it appears that some markets require either activation with a dealer tool or VCD Pro.
  6. #766
    Oct 2013
    Hmmmm may ask my dealer next time im in then as I do now have the option visable on the MIIB screen.
    Sent from my SM-G925I using Tapatalk
  7. #767
    Aug 2015
    Let me know how you get on with that. I did the same thing, showed them the option was there (it was there from the factory, I didn't enable it myself) showed them videos of it working on other cars. They got in touch with VW Germany and were told it should be enabled or even in the menu and they removed it!
  8. #768
    jazzyjames: Sorry to read about your difficulties. It's little solace I know, but you aren't alone in not being able to get this tweak working on a mk7.
    If you still want to persevere, there are some suggestions that I can make, but I stress that these are just guesses that I have put together after chatting with a colleague in Germany (mercifully, my colleague's English is much better than my German)
    Suggestion 1:Ross Tech have made many changes to their software since I wrote the tweak instructions. For example, the current VCDS software version allows the user to perform a "soft reset" of the control module on-the-fly. This facility wasn't available on the version that I used to write-up the tweak (compare the screen shots in my instructions with the picture below).
    What might be worth trying is to reset the BCM after each adaptation channel change (my VCP cable does this as a standard feature). This is done by ticking the "soft reset" box (circled) then Doit! tab - see picture below.
    Suggestion 2: My understanding is that similar problems were experienced with the Skoda Octavia 3, which is also built on the same MQB platform as the mk7 and it used the same RLS/RLHS/RLFS. I'm told by my German colleague that the way that this problem was solved (for the case of the Occy 3) was to only enable Byte 0, Bit 2 (i.e. not activate Byte 0, Bit 1). On the Audi A3 (8V), again which was also built on the MQB platform and again the same RLS/RLHS/RLFS, the tweak worked by using the opposite order of Bits in Byte 0 (i.e. Enable Bit 1, not activate Bit 2)
    You cold try either/both of these permutations
    As I said, these suggestions are long-shots
    PS: If you try these suggestions, I will include your feedback on the tweak instructions
  9. #769
    Aug 2015
    Suggestion 2: My understanding is that similar problems were experienced with the Audi A3 (8V), which is also built on the same MQB platform as the mk7. I'm told by my German colleague that the way that this problem was solved (for the case of the A3) was to only enable Byte 0, Bit 2 (i.e. not activate Byte 0, Bit 1). You cold try this and if it still doesn't work, swap the Bits (i.e. enable Bit 1, disable Bit 2).
    I'll certainly give them a go Don and report back VCDS (VAG-COM) codes and programmable options for Golf Mk7
  10. #770
    Mar 2016
    Slovenia
    Hello,
    1. I am new here on forum, please can you tell me its this to for Passat B8 ? I trying for days to make work rain closing but not working. I have RLHS rain sensor.
    2. I install folding mirrors, and i have activate in door control unit, but still not work. Its here one login code for activate folding mirrors ?
    Tnx
