Page 76 of 198 FirstFirst ... 2666747576777886126176 ... LastLast
Results 751 to 760 of 1974
  1. #751
    Japan
    ZEAL8080: Hello again. I wanted to make clear that my confusion regarding your tweak does not result from your explanation. Rather, it was entirely due to my addled brain (made poorer by old age and a fondness for red wine)! I have thought further about your view and alas, I still can't accept your explanation of the purpose for the "X" and "Y" values in these dimming_curves. But that's OK - both your tweak and mine (using the phototransistor channels) work - so that's all that's necessary. I hope that we can both agree to disagree!
    As you can see, I have included your tweak instructions in a previous post. Hopefully I have done justice to your original work.
    PS: There is nothing wrong with your English - it's very good and it's far better than my knowledge of the Japanese language!
    Hi,Don.
    Thank you for your your reply and sorry for my explanation did not satisfied you yet.
    As I mentioned last msg, my observation may not correct to refrect actual phenomenon of illumination panel control logic, but many friends of "Minkara SNS" folks applied this adjustment. They satisfied day time meter illumination brightness of this approach. Actually they tweak the parameter which they like.
    Anyway I appreciate you to try to understand my input and post my approach too.
    I will check this website that has many good information.
    regards,
  2. #752
    Feb 2016
    Oslo
    I have some strange sound from my speakers when I enter the car. The sound is coming regardless of ignition on/off. Sounds like an identification "whoosh" which lasts for just a second but it's bothering me. This happened after installing a sound system. Is there anywhere in VCDS I can modify the sound system settings? I have been reading on the topic for a MK6 and there you have description and help in the long coding but not for MK7... Has anyone experienced this and any suggests for a fix?
    Thanks all
    2016 MK7 Golf GTE
  3. #753
    Feb 2016
    Oslo
    I have this setting in 5F: "Sporadic ring break detection,Visual". On 2015 Golf MK7 this is set to "none". Does anyone know what it does?
    2016 MK7 Golf GTE
  4. #754
    Quote Originally Posted by Drive View Post
    Drive: Hello - how about sending down some of your nice cold weather!!!
    OK - in regards to your question, I don't specifically know the answer (perhaps someone else here has the answer), but I've only seen the settings "Visual" on this adaptation channel on NAR vehicles for MIB1 units. RoW models appear to have the "none" setting as a factory default
    But ALL of the MIBII units that I have seen (regardless of country - Europe, Australia, USA) have the "Visual" setting from the factory.
    So my guess is that it has something to do with the CAR NET facility which NAR models got in the MIBI units and that is universally available (I believe) in the MIBII units. As you may be aware, CARNET enabled infotainment systems needed to have the "Premium" mobile telephone interface fitted - so there is a rough-logic to my guess (I guess!)
    Why not try setting it and let us know if you make any discoveries?
  5. #755
    Feb 2016
    Oslo
    Thanks for your answer Don! I'm for sure willing to trade the cold for some higher temperatures. Luckily the spring is around the corner.
    I tried to set it to "none", and hopefully this will fix the issue I had with some strange sound from the speakers. It was happening sporadically so it makes sense if this setting solves it. So far haven't heard anything so that's promising...
    Another question: Has anyone been able to enable developer mode for MIB2 with VCDS? When I try to modify the "developer mode"-setting in 5F I get 'out of range' error...
    I would also like to know what "Audio_Managment_Soundset_Menu" does? Default: OFF.
    2016 MK7 Golf GTE
  6. #756
    Apr 2015
    Gold Coast, QLD
    Is there a wiki/post/document containing all tweaks so I don't have to read through 750 posts?
  7. #757
    Apr 2009
    The thread above this one when its at the top...
    Quote Originally Posted by isaacinsoll View Post
    GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
  8. #758
    Isaac: Hello and welcome to the forum. I think what Ozram means is make sure that you are at the Forum shown in Arrow 1 and then click on the thread in arrow 2 (below)
  9. #759
    Apr 2015
    Gold Coast, QLD
    Thanks guys VCDS (VAG-COM) codes and programmable options for Golf Mk7
  10. #760
    May 2013
    the Netherlands
    GTE/E-Golf graphic instead of default:
    Module 5F
    Long Coding
    Byte 2, value 70 instead of 00.
    I will mess some more with this byte. Previously, only byte 18 seemed to influence the specific type of car (GTI or standard).
