As factory fitted, the Halogen DRLs on our Australian mk7s have what is popularly known as "DRL wink". That is, the DRL turns-off on the side of the car where the turn signal is indicating. The VCDS tweak below modifies the behaviour of the DRL so that it counter blinks (instead of "DRL wink") with the turn signal - see the GIFs below. The other functions of the DRL are not modified by this tweak (i.e. the parking light function and the single sided parker function remain unchanged). This tweak is designed solely for incandescent headlight assemblies.
I have implemented this tweak on my 103TSI and I can vouch that it works. Please note that I make no judgement regarding the compliance of the "Counter blinking DRL" with the Australian Design Rules. Those intending to implement this tweak should satisfy themselves in this regard.
VCDS Tweak Instructions: Counter Blinking DRLs - Halogen Headlights
- Select 09 - Central Electr control module
- Select Security Access - 16 from the "Open Controller" screen
- Enter the magic number 31347 and return to the "Open Controller" screen
- Select Adaptation - 10 from the "Open Controller" screen
- From the pull-down button check that the default settings for the adaptation channels shown in the table below are as indicated in the Old setting column
- Change the two Leuchte channels depicted in the table below to the values in the New Settings column
Notes:
- TIP: use the "search" facility on the latest RT software to find the two channels listed below as follows:
- Enter LB4 into the search box to find the Left Hand DRL channel
- Enter RB32 into the search box to find the Right Hand DRL channel
- Only 2 x adaptation channels need to be changed - I've shown the complete Leuchte-set in the table above for completeness.
- Do not proceed with this tweak if the remaining channels are not as shown in the "old setting" column
- If you want the DRLs to blink in unison with the turn signal, , change the setting (instead of the "New Setting" above):
- ( 8 )-Leuchte4TFL LB4-Lichtfunktion C 4 to Blinken links Dunkelphase
- ( 8 )-Leuchte5 TFL RB32-Lichtfunktion C 5 to Blinken rechts Dunkelphase
