Incandescent Tail lights - Add brake function to "inner" lights
The operation of the incandescent taillights on a mk7 is fairly austere (IMO)! Particularly the "inner" lights that are fitted to each side of the hatch door. As stock, these lights do nothing more than function as parking lights and in this mode, they are programmed to illuminate to 28% of full intensity. The "outer" lights work a bit harder in that they function as brake lights, general parking lights, and as one-sided parkers- when the indicator stalk is activated and the car is locked.
Fact is that any of the tail lights (and all exterior lights on a mk7) can be programmed to function in a variety of ways because of the manner in which VW has implemented the Body Control Module (BCM) on MQB platform vehicles. However, the ardour of those interested in creating these tweaks is limited by the boundaries set by the Australian Design Rules (ADRs) which specifies how cars must be lit (amongst other things).
I developed the tweak below to make the inner lights on my incandescent tail light assemblies work harder. In essence, the tweak adds the "brake" function to these two lights so that both the outer and inner tail lights (on both sides) will illuminate together when the pedal is pressed - as well as the high level brake light (see my animation below). I argue that this makes my vehicle more "visible" to the cars behind when I'm braking.
The stock "parker" function of the inner lights is unaffected by this tweak, and I have placed the new function in the Leuchte cannel-set so that the brake lights always have priority over the parker function. I assume that the tweak complies with the ADRs, but I advise that those seeking to implement these instructions should satisfy themselves in this regard.
VCDS Tweak - Add "brake" function to "inner" tail lights
- Select 09 - Central Electr control module
- Select Security Access - 16 from the "Open Controller" screen
- Enter the magic number 31347 and return to the "Open Controller" screen
- Select Adaptation - 10 from the "Open Controller" screen
- From the pull-down button change the adaptation channels shown in the table below to the New Settings as indicated:
Notes:
- The adaptation channels settings on (9) and (11) for the left and right side lights do not need to be changed. I have included these in the table to complete the alpha-channel sub-set entries
- Do not implement these instructions if the Old Setting values are not the same as shown in the table
Golf mk7 - Control Module Security Codes
As a forum community exercise, it would be advantageous for both our fellow colleagues and for ourselves to create as fulsome a list as possible of the security codes for the control modules in the mk7. If you are like me, you would doubtless have some of these security codes recorded somewhere for the VCDS tweaks that you have tried.
Below is a list of the security codes that I have obtained from various sources (not sure where, now). I'd welcome other's views as to the veracity (or, otherwise) of the numbers in my table.
If you can add to my list, then I urge you to do so (as a resource for other VWW members and for those that visit this site from time-to-time). I will undertake to consolidate replies into a single list (with appropriate attributions and comments from those that respond).
Please contribute to this list, if you can.
Thanks in advance
Golf mk7 Control Modules - VCDS Security Codes
Control Module |
Security Code |
Contributor |
Comments |
01 -Engine |
27971
79153 |
DV52 |
02-Auto Trans |
2b-Steer. Col. Lock |
20103 |
03- ABS Brakes |
25004
11966
15081
18573
20103
24435
24990
25004
25757
28183
31857
37202
40168
44595
40304
10505
19249
10815 |
zloybob
zloybob and
acr2001 (RT forum)
Rainesh
kawzx7
Morde
Dana (RT) |
Brake booster adaptation only
11966 was able to deactivate hydraulic brake assist -Yomny (Golfmk7 forum)
XDS changes
24990 - for All Adaptation channels
straight ahead brake stabilization
25757 -brake stabilization
for Adaptation/Basic Setting
brake disk drying |
3C-Lane Change |
20103 |
LIJetta_18 |
05 - ACC/Start Auth. |
20103 |
08-Auto HVAC |
20103 |
09-Cent. Elect. |
31347 |
10-Park/Steer Assist |
71679
20103 |
13- Auto Dist. Reg (ACC) |
14117 |
Morde |
14- Susp. Elect. |
20103 |
NEtech |
15-Airbags |
16-Steering wheel |
17-Instruments |
20103
25327
47115 |
Zloybob
djduese (RT forum) |
Not applicable to MY16 models
Accepted on MY16, but no access to adaptation channels
for post MY16 control modules |
18-Aux Heat |
20103 |
19-CAN Gateway |
20103 |
32-Differential Locks |
42-Door Elect, Driver |
20103 |
44-Steering Assist |
19249
28183
44595 |
DV52
DV52 |
52-Door Elect, Pass. |
20103 |
55-Headlight Range |
20103
15284 |
5F-Information Electr. |
20103
S12345 |
A5-Frt Sens. Drv. Assist |
20103 |
A9-Struct. Borne Sound |
6D |
12345 |
Morde |
75-Telematics |
20103 |
Chillout |
