Originally Posted by
MRG_AU
I wonder why disable stop start coding - voltage method did not work on mine. Value 12 is not accepted. Says out of range. Should I be entering 12.0? I understand your instructions as temperature method is for MY13. Voltage method from MY14. I have not tried the temp method.
I want start/stop enabled but I want to know which method applicable if I want to disable it later.
thanks once again for sharing your knowledge @DV52
MRG
MRG: Hi again. Not sure about why you can't enter 12, but as indicated in my notes, I understand that any value higher than 10 (volts) will be sufficient to disable Stop/Start. I have a my13 model so, I don't have access to this channel on my car. But, what I would try (if I did have access) is to work back from 12 and keep entering progressively lower values until the channel accepts one. Please let me know what happens and I will add your feedback to the tweak instructions. Just revert back to your original value if you want to keep SS operational
Thanks again
