VCDS (VAG-COM) codes and programmable options for Golf Mk7
I wonder why disable stop start coding - voltage method did not work on mine. Value 12 is not accepted. Says out of range. Should I be entering 12.0? I understand your instructions as temperature method is for MY13. Voltage method from MY14. I have not tried the temp method.
I want start/stop enabled but I want to know which method applicable if I want to disable it later.[emoji4] thanks once again for sharing your knowledge @DV52
MRG
Thanks for sharing your thoughts agentthumb, i agree that without properly knowing what happens if we do a change with VCDS could be very dangerous.
My wife drives the golf and she complained she did not like XDL in strong mode. steering felt a bit hard however it gets in n out of corners nicely. But she preferred standard. I reverted it back to standard last night.
I believe changing how external lights operate at least to the extent I have changed should not make any difference to the warranty. Because I do not think they would result in any issues. Am I wrong!
