Auto Rain Close -mk7 VCDS tweak
EDIT NOTE: since I first wrote the instructions below- the forum community has learned much about this tweak. From this experience, it now seems that the success, or otherwise of the Auto Rain close facility is dependent on having the correct rain-sensor installed on the front windshield. Again from experience, it appears that the car MUST have a rain sensor with the part number 5Q0 955 547 WITHOUT ANY SUFFIX to be more likely to succeed. VCDS will report the correct sensor as RLFS, not RLHS. (thanks hadez16 & darkchina811 from RT forum)
Background
It's fair to say that the Auto RainClose tweak has had a dubious infancy when applied to MQB platform vehicles like the mk7 Golf. My understanding from conversations on various forums is that problems were first encountered with this tweak because of the new sensor that was installed in these cars.
In previous models, VW used a "RLS" (i.e. Rain Light Sensor) to control Auto RainClose. However, in many of the mk7 models, the sensor that was introduced was the "RLFS" (Rain Light Humidity Sensor, or in German, Regen, Licht, Feuchte Sensor). Some VCDS auto-scan listings now report this new sensor as its Anglicized name, "RLHS" and of late, the RLS seems to have re-appeared in some mk7 scan reports (particularly in NAR cars).
As a result of early problems with the Auto RainClose tweak, the folk at Ross Tech (i.e. the inestimable Dana) modified the VCDS software so that it would communicate correctly with these new sensor units. The first SW version in which these changes appeared was Beta ver. 14.6.1. At the time of writing, Ross Tech has advised that their Beta software (i.e. currently Beta 14.8.1) is still the only version with the necessary smarts to talk to the sensors on mk7 vehicles. Doubtless, in the fullness of time (to quote Sir Humphrey Appleby), RT's non-beta software will be modified to accommodate these new sensors.
Edit - Nov 2014: Ross-Tech's full version software (SW version commencing with the number "14", or greater) is now able to fully communicate with the rain sensors in mk7 vehicles. |
The material in these instructions have been sourced from numerous forums and a skeletal version of these procedures can be found on the Stemie.de site.
Particular acknowledgement is given to the findings of the folk on the VCDS thread on VWvortex. In addition, recognition must also be given to those talented and amazing VCDS gurus on the Ross Tech forum for unravelling the early problems with the RLFS. Thanks to you all for your valuable contributions.
A word of caution for those that wish to proceed. This is one of the more complex tweaks and as a result, particular care and precision in following these instructions is required. Feedback from others indicates that a few have not been able to make this tweak work albeit I have received lots of reports of its successful implementation. If you fall into the latter category-congratulations. For those in the former category, please revert all settings to their original values (and re-check the entries for "opening and closing" in the Discover media screen which may have altered because of the factory reset process-see part 3 of these instructions). And, if you have implemented this tweak and you want to revert back to the car's original settings, make sure that you use RT's Beta software for the roll-back process.
If others can add to the information in these tweak instructions, please do so. If you want to PM, I'll undertake to modify this post with any updates - or you can add your own separate post to this thread.
For ease of understanding, these instructions have been broken-up into three discrete parts as follows (it is recommended that the instructions should be followed in the sequence listed):
This PostPart 1: Auto RainClose - Coding Changes
Post #230Part 2: Auto RainClose - Adaptation Channel Changes
Part 3: Auto RainClose - In-Car, setup procedures
All parts must be completed
Ross-Tech software version commencing with a number "14", or greater must be used for this tweak
Part 1: Auto RainClose - Coding Changes1. From the Installed tab on the Select Control Module screen, select 09-Cent. Elect.
2. On the Open Controller screen for address 09 - Cent. Elect., click the Coding - 07 tab
3. When the screen below opens, click on the pull-down down tab in the middle of the screen (as shown next to the red arrow). As indicated in the picture, the BCM (Body Control Module) has two "slave" modules, one of which is the RLFS
4, Select
RLFS and click on the
Long Coding Helper tab.
Note 1: on some mk7 vehicles, the slave module will be RLS, or RLHS |
5. Select
Byte 0 and place a tick in
Bit 1 and
Bit 2 as shown in the picture below. Exit this screen
6. When the screen below appears, ensure that the
New coding box contains the Hexadecimal value
06A8DD Click the
Do it! tab. Go back to the
open controller screen
Note 2: some forums report "error 31" message at this point. If this error message appears, manually enter 06A8DD into the New coding box instead of using the Long Coding Helper. Then click the Do it! tab |
Note 3: On some mk7 vehicles, the default coding string for the rain sensor is 01E8DD. If this is the case, the required hexadecimal value in the new coding box is 07E8DD. |
Go to Part 2(next post)
Auto Rain Close - mk7 VCDS tweak (parts 2 & 3)
Part 2: Auto RainClose - Adaptation Channel Changes7. Once the
Open Controller screen appears for
address 09, click
Security Access -16 tab
8. When the Security Access window opens, enter the magic number for the Body Control Module as per the dialogue balloon (i.e.
31347). Click the
Do it! tab
9. When the
Open Controller screen re-appears, click
Adaptation - 10
10 . From the pull-down channel menu, select
(15)-Access control 2-Regenschliessen_ein_aus. and select
active in New value box. Click
Do it! tab
11. Select (
16)-Access control 2-Regenschliessen_art and select
Permanent in New value box. Click
Do it! tab
12.
Select (28 )-Access control 2-Menuesteuerung Regenschliessen and select active in New value box. Click Do it! tab.
Note 4: this adaptation channel change adds "Automatic closing in rain" as an option-panel in the Discover Media menu screen (see Part 3) |
13. Exit the VCDS software and remove VCDS cable from the OBDII port
Go to Part 3
Auto RainClose - Factory reset procedure
This tweak requires that the control unit be reset after the coding changes above have been made. This is done using the following steps:
- Press the CAR button on the RH side of the Discover media Unit
- Press the set-up panel on the bottom RH side of the screen
- Select Factory Setting panel (it's the very last entry on the list)
- On the Factory Setting screen, select Reset Mirror and Wiper Settings
- Press the Reset panel
Auto RainClose -Menu enabling procedure
For Auto RainClose to work, the function must first be enabled in the Discover media screen. This is done using the following steps:
- Press the Opening and Closing panel
- Place a tick in the Automatic closing in rain panel as shown in the picture below.
- Make sure that the settings for all other options (especially in Opening and closing) are appropriate and that they have not been changed by the factory reset process above (e.g. check that Convenience opening option isn't set to "off")
- Exit the screen
source - 3askoul/www.Golfmk7.com
Auto RainClose - Test and operating procedure
- Make sure that the wiper stalk is in the rain sensing position (i.e. up one position) and that the headlights are switched to the Auto position
- Wind down one, or more windows, and/or sunroof
- exit and lock the vehicle using the remote fob or KESSY
- Wait a minute, or two and pour water on the rain sensor, or tap the rain sensor with your fingers.
- The open window(s)/sunroof should close
Note 5: a further feature of this tweak is that if the window(s)/sunroof is left open for an extended time (generally overnight) without rain, or intervention, the open aperture(s) will be automatically shut. |
Feed-back from forum members:
Quote:
Originally Posted by sucnip
Hi. I finally got the rain closing working over the weekend. I noticed that once I reset the closing settings I lost window up/down functionality on the remote. I had to manually wind each window up and down, restore auto up/down functionality before the remote started working again. Just thought I'd mention that in case you'd like to add it to the FAQ.
Quote:
Originally Posted by Kiaorana
one member mentioned he got this tweak working by changing the sequence order, he did 2,3,1.
