Page 197 of 198 FirstFirst ... 97147187195196197198 LastLast
Results 1,961 to 1,970 of 1974
  1. #1961
    Quote Originally Posted by CSD View Post
    Now, the GOOD news............Works as it should!
    hmm......... Please understand that I'm a firm believer that how folk program their cars is their decision - but I invite that you consider an alternative view!
    When I look at your videos, my primary observation is that there is lots happening on the tail-lights on this car when you activate the turn-signal function!! Many years ago (probably before you were born) - a very eager math professor tried to instill into my much younger brain the concept of a zero-sum-game, which can be also applied to lighting design IMO.
    Not sure if you are familiar with game theory - but the concept when applied to lighting design ostensibly says that there is a fixed amount of attention that drivers at the rear of a car will use when reading tail-lights.
    Importantly, the concept of a zero-sum-game says that different lighting designs CAN'T increase the total quantity of rear-car driver attention (it remains the same for individual drivers). Various different designs can only shift the amount of attention that the driver devotes to decoding each of the lighting functions on the tail-lights.
    So, applying this theory to your video, my conclusion is that it's very unlikely that drivers at the rear of this car will miss your intention to turn left/right. However, I wonder whether in achieving this outcome, the obvious emphasis on turn-signal in this lighting set-up will overpower the Brake light?
    Of course, each and every lamp illumination on the tail lights is important because it indicates the driver's intention to cars at the rear - but it could reasonably be argued that when comparing the priority of functions, the driver's intention to stop is the highest!
    My question is particularly relevant (again IMO) in this case given that this design illuminates both outer and inner lamps at full illumination (i.e. the same illumination level as the single Brake-light on each car-side) and now the non-blinking Brake-light must also compete with the elevated emphasis on the turn-signal function!
    Once more, entirely your decision - I'm highlighting the matter for your review!!
    Two issues, #1.
    It seems that I have lost a function. The "Parking Lights/Position Lights" are no more illuminated when I open/close the vehicle (Coming Home/Leaving Home function), only the license plate LED bulbs are visible on the rear end.
    I'm confused! When I re-examine the Leuchte-set table in your previous post - I don't see the CH/LH Leuchte-commands on the PL lamps! Do you mean the Single Side Parking Light (SSPL) function that is enabled when the turn-signal stalk is activated prior to locking the vehicle? I ask because your table does have SSPL included on these lamps
    If you want SSPL, do this:
    Left-Side Parking-lights
    Lichtfunktion G > Parklicht links (beidseitiges Parklicht aktiviert li & re)
    Lichtfunktion H > nicht aktiv
    Dimmwert GH > 127
    Dimming Direction GH > maximize
    Right-side Parking-lights
    Lichtfunktion G > Parklicht rechts
    Dimmwert GH > 127
    And assuming that CH/LH has been correctly activated in the non-Leuchte channels on the hex09 module - if you also want CH/LH on these lamps:
    Lichtfunktion H > Coming Home oder Leaving Home aktiv
    #2
    Later edit: something else I have noticed.
    With the car being off and locked > hazard lights ON
    Only the yellow turn signals are being triggered, normal behavior I assume.
    This I find very important during night time if, for any reason I have a breakdown on a secondary road.
    Can the "Parking Lights/Position Lights" be triggered as well?
    So, here's the thing - the way that the hazard warning ights are operated on the VAG stable of vehicles is determined outside the scope of Leuchte-programming. By design (I think), if the ignition is turned-OFF and regardless whether the car is locked, or not - the hazard warning lights are dedicated to the factory blinker lamps (both front and rear).
    There is a way of conjoining other lamps into this scheme - but in this case, we have run-out of spare Lichtfunktion channels because of the quantity of light functions that you have requested on the PL lamps.
    However, I have just inputted this tweak into my "virtual mk7" (see below) and according to the behavior of the simulated lights on my test-bench, you should be able to trigger the hazard warning functions on the PL lamps if you turn the key to the ignition-ON position.
    Alas that's the best that I can deliver -as I have said, the limitations of the Hazard lights are beyond Leuchte programming
  2. #1962
    Oct 2023
    Europe
    Regarding #1
    That did the trick for the Single Side Parking Light (SSPL)! Added your settings for all four Leuchte-sets (16, 17, 23 & 24). I know it's weird that they were not showing up before in my previous screenshots, yet, they worked for CH/LH.
    I was not, but thanks for your suggestion, seems like a great topic.
    Maybe I am biased due to the fact that I owned most of my life USDM cars that worked in a similar fashion. Never had any issues or complaints, they were driven in Europe all of their life.
    I will set up my phone tripod and re-create the video, with brakes applied. I am not sure why, but imho the actual brake LEDs embedded in the tail lights seem to illuminate way stronger than the DRL strips (even when set to have a 127 value).
    I will decrease the values of the "Klemme 15 ohne Nachlauf", from 127 to 100.
    The brake LEDs are also having a value of 127, along with the central brake light on tailgate.
    Left-side Parking-Light Lamps
    Lasttyp > 43 - allgemeine LED
    Lichtfunktion A > Blinken links Hellphase
    Lichtfunktion B > nicht aktiv
    Dimmwert AB > 0
    Lichtansteuerung HD AB > Always
    Lichtfunktion C > Klemme 15 ohne Nachlauf
    Lichtfunktion D > nicht aktiv
    Dimmwert CD > 100
    Dimming Direction CD > maximize
    Lichtfunktion E > Blinken links Dunkelphase
    Lichtfunktion F > nicht aktiv
    Dimmwert EF > 10
    Dimming Direction EF > minimize
    Dimmwert GH > 100
    I will do two videos for comparision to see if the 100 and 127 values make a real difference. My priority of course, is to focus the attention on the brake lights.
    Regarding #2
    Not sure why it didn't crossed my mind to leave the car in accessory mode. Maybe my worst case scenario was that I had to leave the car unattended with no occupants and locked. I believe there was a way to lock the car with the key inside and lock it with the spare key. But I think that was only with the engine running. Mine has a KESSY starting system.
    I will edit this post once I do the videos.
    Many thanks again for your time and knowledge.
    Dan.
    Later edit:
    Lamps in action:
    Settings used for all (with the appropriate left & right)
    Dimmwert AB > 0
    Dimmwert CD > 127
    Dimmwert EF > 10
    Dimmwert GH > 127
    Lamps in action with reduced values
    Dimmwert AB > 0
    Dimmwert CD > 100
    Dimmwert EF > 10
    Dimmwert GH > 100
    I feel that adjusting the 127 to 100 values doesn't do a difference. Maybe I should do a close-up video.
    Filmed in 4K @ 60fps but YouTube doesn't show it yet. The lightning in the underground parking is also strange.
  3. #1963
    Nov 2023
    UK
    For those wanting to customise the instrument panel lighting by creating their own "dimming curves", I have written a short paper on how I developed the settings for these instructions. The document can be down-loaded HERE. Also included in my paper is a link to a spreadsheet macro that I created to calculate the settings for the "X" and "Y" values for this tweak. If you want to develop your own "dimming curves" then this spreadsheet might also be useful
    DV52 - please could you provide an updated link to your document for dimming curves?
  4. #1964
    Nov 2021
    Herford
    Hallo,
    is this the coding where when the hazard warning flashes,the LED U also flashes on a golf 7 r model 2015??
    If not,does anyone happen to know how I can get the LED to flash when the hazard lights are flashing.
    Just like this police flashing headlights.
    Iwould like to have that on my MK7R 2015 Europe version.
    Kind regards from Germany
  5. #1965
    Nov 2021
    Herford
    Led headlights U from MK7 R 2015 .please coding to hazard.
    sry my english not good
    from germany
  6. #1966
    Franky: Hallo.
    If you look at my tweak HERE, you will find a set of instructions for adding the 3rd Brake light to the hazard warning function.
    In theory, a similar set of changes should work for including the hazard warning function into the "angel-eyes" (U LED lights) on your Golf R. BUT - I suspect that it's not possible for the following 2 x reasons:
    1. The LED lights on angel-eye fittings operate differently to the other exterior lamps in that they use 2 x separate Leuchte-sets: one for the lighting functions and a second Leuchte-set for the power-supply to the fittings
    2. The Leuchte-set for the lighting functions is normally fully subscribed - meaning that there isn't sufficient spare adaptation channels in the Leuchte-set to implement the hazard warning function
  7. #1967
    Feb 2024
    Bulgaria
    From this experience, it now seems that the success, or otherwise of the Auto Rain close facility is dependent on having the correct rain-sensor installed on the front windshield. Again from experience, it appears that the car MUST have a rain sensor with the part number 5Q0 955 547 WITHOUT ANY SUFFIX to be more likely to succeed. VCDS will report the correct sensor as RLFS, not RLHS. (thanks hadez16 & darkchina811 from RT forum)
    Hello, I want to enable this function on my VW E-Golf 2016 (VW Golf 7), U.S Editon.
    I think that I have enabled/changed all the things except Part 1: Auto RainClose - Coding Changes ...
    I already have the Auto Rain Closing in the Infotainment system menu.
    Here is the raw data from my OBDEleven Bluetooth diagnostic tool:
    So I go to
    Central Electrics-Subsystems - RLHS > Info:
    I will provide any other info needed.
    I just want to know that the Coding value should be in order this to work ?
  8. #1968
    Feb 2024
    Alberta
    Quote Originally Posted by ArdiL View Post
    I just wanted to finish by adding a quick video of what my rear lights look like after all the coding.
    Attachment 54964
    Attachment 54965Attachment 54966
    I just modded my 2021 Canadian Mk7.5 GTI and it works perfectly! With the NA models the signal light also acts as another brake light.
    One thing for my car in the coding there was no "Brake Light" for A16/17 and A23/24 so I used the German translation of "Bremslicht" for those entries.
    Thank you!!
  9. #1969
    Jun 2024
    London
    Hi 2016 Vw Passat with halogen headlights and halogen daytime runnings lights in fog lamps. Trying to get daytime running lights to stay on with headlights. Ive been through adaptations list but its all german. Anyone know which line to go for
  10. #1970
    Foru2justnv:Hi and welcome to the forum!
    Before addressing your question - let's discuss why the DRLs on this car are factory coded to be switched-OFF when the low-beam lights are activated. This happens because the reflectors in the DRL fittings (also called the "Luminaires") do NOT have the correct cut-off characteristics for nighttime operation.
    This means that the DRLs will blind drivers in on-coming vehicles if fully illuminated at nighttime. So, an important part of the tweak to switch-ON DRL with low-beam lights is a dimmed DRL illumination-level after-dark - which is 31% !
    For the safety of your fellow drivers, please ensure that this requirement is adopted with this tweak - details of which can be found HERE.
    Also, please note that my tweak was written for Aussie vehicles. As such, the instructions are predicated on the default values shown in the "Existing settings" column of the tables in my link. If this UK vehicle does NOT have the same default values - please post-up ONE of the DRL Leuchte-sets. To be clear, I need to see ALL 19 x adaptation channel values in your data!
