Page 186 of 198 FirstFirst ... 86136176184185186187188196 ... LastLast
Results 1,851 to 1,860 of 1974
  1. #1851
    Pacific Paradise QLD
    You can turn off the noise with an OBDEleven
  2. #1852
    Quote Originally Posted by Splashalot View Post
    2018 Mk7.5 Golf GTI. Does anyone know if it is possible to decouple the rear parking sensors from the rear view camera? I need my rear view camera when reversing into my tight garage, but the constant beeping from all sensors drives me nuts. If I turn off the sensors the camera goes with it.
    Hi.
    Yes, it is indeed possible to adjust a couple of aspects of the "constant beeping" from the sensors separate from the operation of the rear view camera (and the rear sensors separate to the front sensors too).
    It's all done in the Park-assist (VCDS)/Parking Assistance (OBD11) module that normally lives @ address hex10 (VCDS)/hex76 (OBD11) on the CAN network.
    The pertinent adaptation channels are:
    • MAS01426-Speaker volume for rear park assist
    • MAS01427-Speaker frequency for rear park assist
    • MAS01428-Speaker volume for front park assist
    • MAS01429-Speaker frequency for front park assist
    And if you have PLA 3.0 fitted, you can also use the channel Park assist activation tone > ON/OFF
    Notes:
    • The allowable values for the channels above are defined in "Stage #" - so the lower the number, the lower the frequency, or sound volume. You might want to greatly diminish the volume - rather than delete it entirely, maybe?
    • Of course if you are using OBD11 as your diagnostic tool - ignore the leading Tag number in the channel descriptor.
    • If you are asked for a security code, try 20103, or 71679.
  3. #1853
    Mar 2007
    Hobart
    Thanks for the responses. If I understand correctly, these measures turn off the sensors' beeping in all circumstances?
    Just to clarify - what I'd like to do is have the option of turning off the beeping by using the centre console button, whilst not affecting the rear camera operation.
    Basically, have the sensors operate normally at all other times apart from when reversing into my tight garage, where I can use the console button to turn them off.
    Cheers.
    2018 Golf GTI, Manual - gone.
    2017 Golf 110tsi Trendline, manual (gone - gladly)
    2007 Golf GTI, Manual, (gone - sadly)
    1978 Golf GLS; 1972 Superbug, (memories)
  4. #1854
    Yes- that's correct- "in all circumstances" whenever Park Assist is active
    I'm happy to be told otherwise, but I'm not aware of any way to make the center console button for Park Assist operate different to factory setting (which is to turn ON/OFF the entire Park Assist function as set-up in the module channels).
    Of course Park Assist doesn't know about reversing into your tight garage - but how about using the sound-off software button labelled 5 on the MIB screen below? (if you move your hand towards the left or right-hand side of the screen, the function buttons below should appear - the operation of the software switches should be explained in your manual)?
  5. #1855
    Mar 2007
    Hobart
    Well they say you learn something new everyday! I never knew that menu existed. Thanks, Don - there really is no end to your helpfulness. Cheers.
  6. #1856
    Mar 2014
    Newcastle, NSW
    Enable ACC follow distance menu
    Works on my Mk 7 R. Has a replaced ACC radar 5Q0 907 572 F.
    Hex 13. Auto Dist Reg.
    Security access. Code 14117
    Adaptation (10). IDE00899-Option for presetting of time gap. Change Off to On.
  7. #1857
    Nov 2021
    Brazil
    Quote Originally Posted by hardy_bm View Post
    Hi Hardy_bm,
    What exactly does this setting do?
    Thanks,
    Paulo.
  8. #1858
    Paulo: It's a well established tweak now for MQB platform cars - By default, the inter-vehicle distance setting of ACC (Adaptive Cruise Control) is factory set to distance 3. So every time that ACC is enabled, the setting defaults to distance 3.
    The tweak enables the default inter-vehicle distance value to be changed to whatever the driver chooses
    PS: depending on the type of hex13 module, the alternative channel can be IDE01949-Distance basic setting option > ON (and reset MIB/MMI)
  9. #1859
    Jul 2010
    in the Superb (also an MQB platform car) - the setting "Last distance selected" can be turned on via the Infotainment screen, so it remembers the last distance set, everytime u enable ACC.
    comes with this menu option from factory.
    VCDS (VAG-COM) codes and programmable options for Golf Mk7-acc-settings-jpg
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  10. #1860
    Quote Originally Posted by dArK5HaD0w View Post
    dArKrHaD0w: yes- that's exactly what happens when the adaptation channel in @hardy_bm post is set to ON. This value enables the screen in your post.
    I've no idea how VW decides which models it will factory set to show the distance menu in the MIB - but it certainly doesn't happen for ALL cars
