Page 183 of 198 FirstFirst ... 83133173181182183184185193 ... LastLast
Results 1,821 to 1,830 of 1974
  1. #1821
    So for us technically challenged it means that a light appears on the dash in concert with the brake lights??????
    @Hillbilly: for both the "technically challenged" and for the technically unchallenged - it does indeed mean the same thing; "it means that a light appears on the dash in concert with the brake lights"
  2. #1822
    Pacific Paradise QLD
    LOL I have often wondered what the brake lights are doing when using ACC so will enable this as i sometimes wonder when it brakes hard if the following cars are aware Im slowing quickly
    Will look shmick with my tail lights flashing with the indicators. ROFL
  3. #1823
    @hillbilly : of course, the tweak WON'T actually change any tail-light behavior - it just mimics the brake-light activity on the dash LED! Ain't no "shmick"-ness possible with this tweak - alas
  4. #1824
    Yeah I realise that(was just joking) and cant find the "Tail lights" in the adaptations in G15 on just looking before I plug into car Maybe its in German???
    I can find Bremslicht which is the closest I can find to Google translator
    Brake lamps= Bremslichter
    Or Brake lamp= Bremslicht
    Have done all that and it works but I seem to have a new green icon in the dash for "Press foot brake" . When I do so the light as said above comes on and the light on the dash goes out and comes on again when I lift my foot off brake. It is immediately above the ACC symbols and slightly to the left of it.. Dont remember seeing it before?????????????
  5. #1825
    @Hillbilly: yes, VCDS reports the setting as "Brake lamp" and OBD11 calls it "Bremslicht". Not sure about "Press foot brake" because I don't know your car. But I suspect that the message was always there - the tweak doesn't change anything on the hex17 module.
  6. #1826
    Car is as in Sig and I reversed the adaptation and its still there It also brings up a message saying "Put foot on footbrake" which i havent seen before but is was still there after reverting so Im unsure . Just it seems different.
  7. #1827
    @Hillbilly: clearly I can't dissuade you from believing your suspicions - so I won't try. If you can be swayed by the brutal logic of a wiring diagram, then the arrangement below should be compelling. It shows that the hazard warning light is controlled ONLY by J519 - which is the module that VCDS calls "BCM" and OBD11 calls "Central electrics".
    As I have said - nothing in the tweak impacts on the hex 17 module (the dashboard/instrument cluster)
  8. #1828
    Yes I believe you and its my own fault for not looking before changing anything. However i have never had the message pop up before. or maybe Ive always had my foot on the brake when I turn car on. Going for a 200k drive tomorrow so will see what happens
  9. #1829
    Well results from todays drive are extremely inconclusive as my hazard button is in a position that is constantly in sunlight and therefore impossible to tell if its lit or not. So while the mod works its virtually useless on sunny days.
    Havent figured out the handbrake message yet but the icon goes away when I start moving..
  10. #1830
    Mar 2021
    Norway
    Hope someone can help me with this? Does anyone know how to change this white (the one above temperature) line to blue?
    Where can I change this with VCDS?
    White:
    Blue:
    Hope anyone can help, thanks!
