Page 178 of 198 FirstFirst ... 78128168176177178179180188 ... LastLast
Results 1,771 to 1,780 of 1974
  1. #1771
    May 2020
    Canberra
    Quote Originally Posted by quailallstar View Post
    Nevermind! Don have me the codes and I can confirm it works. Posted it on YouTube.
    YouTube
    Sent from my SM-G965U using Tapatalk
    I can only see the Start System Interface module in my car on OBD11, but not the codes in the video. It's a brand new GTI, any thoughts, I'd like to have this activated.
    MY20 MK7.5 Golf GTI - Tornado Red - LP/S&SP
    MY19 AW Polo - Comfortline - DAP
  2. #1772
    Pacific Paradise QLD
    Quote Originally Posted by genebaby View Post
    If its a 2020 MY20 you may not be able to do anything much to it due to VW blocking access
  3. #1773
    May 2020
    Canberra
    Yeah, I don't have a KESSY control unit, so I'm not sure of where else to go.
  4. #1774
    If you reply with quote we know who you are replying to as a reply is just to the thread
  5. #1775
    May 2020
    Canberra
    I was replying to you, the instructions are for the KESSY control unit, you need to go to YouTube to see them.
  6. #1776
    If you are talking about the pulsing light in the start button already done that and its a waste of time. I put mine back to normal
  7. #1777
    May 2020
    Canberra
    Yes, that's what I'm interested in, I saw before that the Mk8 does this and it was something in the new car I didn't mind.
  8. #1778
    Genebaby:hi again
    The instructions that I wrote for the heartbeat tweak in VCDS speak were intended to apply to the KESSY module called Acc/Start Auth. which lives @ address hex05 on the CAN network. The particular hex05 module in my car is 5Q0-959-435 (EV_KessyHellaMQBAB).
    On some later model MQB vehicles, the equivalent KESSY module is called Access Startsystem Interface and the address is hexB7 - but they still have the descriptor 5Q0-959-435 (EV_KessyHellaMQBAB).
    I don't have a channel map for the hexB7 modules, but I'm surprised that the 2 x channels in the tweak are missing on your car.
    When you have selected the hexB7 module with OBD11 on your car and you have chosen adaptation option, you should be presented with a search box. If you enter Search lights into this box, you should be able to select DeveloperCoding: Search lights. Once you do this, you should then have access to ZAT_illumination_concept_mybeat_clamp58xt and ZAT_illumination_modus_mybeat_clamp58xt in the list of channels - which you can set to activated
  9. #1779
    May 2020
    Canberra
    Thanks Don, l will check my car when I get home from work and see how this goes with your information.
  10. #1780
    Its an App in OBDELEVEN to flash the start engine button
