Page 175 of 198 FirstFirst ... 75125165173174175176177185 ... LastLast
Results 1,741 to 1,750 of 1974
  1. #1741
    Jan 2020
    I’d have to so no to that one. I can’t see vow or Audi allowing a third party software to make changes to car other then audio functions.
    If anything it be linked to the headlight sensor sensing a change of lighting that is coded to know it’s in a tunnel or a closed environment
  2. #1742
    Would be an interesting project.
    Firstly you'd have to sniff the comfort databus and try and find if there is a recirc message.
    Then use something like an Arduino nano to send the messages when triggered by your location on your phone.
    Sent from my SM-G960F using Tapatalk
  3. #1743
    Interesting if I could have pulled it off... No problems this side of the diagnostics/obd things if going android based response or arduino. But me sniffing sockets in canbus data. Well a little bit too much of a challenge for me.
  4. #1744
    Jan 2020
    You can get short term subscriptions for Odis online.
    It would be good if this site raised some funds so we could have an actual account to share around.
    Even a registry system where we could share around special tools. I’m in desperate need for a DRC charging kit so I can install some lowing springs on my RS5.
  5. #1745
    I think you might be confusing Erwin with ODIS
    Yes you can buy 1 hour access to Erwin to print out wiring diagrams, workshop guides etc. Anyone can do this.
    ODIS is the factory/dealer diagnostics suite which is not available for casual use. In Australia it is only available to dealers.
    In Europe and the US independent workshops can also apply and pay for access on an annual basis.
  6. #1746
    Jan 2020
  7. #1747
    Yep that's not VW.
    Not something that can be supported by the forum for obvious reasons.
  8. #1748
    Pacific Paradise QLD
    Looks pretty sus to me as VW said it wont work away from workshop so that outfit is pirating on someones account which is against forum rules isnt it
  9. #1749
    Sep 2019
    Does anyone know if it is possible to enable Dynamic Light Assist on a Mk7.5 GTI through coding?
    I have a MY19 model that doesn’t have dynamic cornering lights or dynamic light assist advertised as standard.
    It seems there are people online who have got it working on a Passat and Arteon.
  10. #1750
    Mar 2020
    Mel, QL
    Hello DV25!
    I recently found this forum and your thread is really helpful in "completing" my VW.
    Some of the tweaks are relly mind-blowing-good!!
    Recently I came up with an idea about an odd idea...
    I tried to keep the Front-Field-Lights(the puddle lights under the mirror) turned-on while reversing the car.
    For my VW came up with the 360°Camera function(so called bird-view camera or something like that...), and I can see nothing on both side of the car at night when reversing into my spot, but as soon as I open my door(the puddle lights turn on), they went crystal clear...LOL
    I was thinking whether I can "link" the puddle lights to the reversing-light(
    Leuchte28/29) in the way of changing the adaptations somewhere(may be in the 09.central electric...)
    But finally i came up with no result....
    Would you please help me with this?
    Thanks!
    Fashionci
