Page 173 of 198 FirstFirst ... 73123163171172173174175183 ... LastLast
Results 1,721 to 1,730 of 1974
  1. #1721
    Would this also work in a TIguan
    Have slighty different things on 09 like but none of identical to above
    Kessy comfort oeffen Not active
    Kessy comfort shliessen Active
    Kessy Protokollvariant Entry Exit Not active
    Kessy Ruephase Entry Exit Not Active
    Not sure - but try it. The settings can always be reverted back if it doesn't work. And, it might be worth factory reset on the MENU screen (definitely, don't use the factory reset in OBD11/VCDS) after the settings are changed
  2. #1722
    Pacific Paradise QLD
    Yeah realise that. I thought your German may be better than mine LOL
    There is nothing about key start in there
  3. #1723
    ^ ^^^ this is a pic of the Battery monitor module (J367) that is connected to the negative terminal that Hillbilly refers-to (I think). J367 is basically a coil of wire with a few electronic components embedded in a resin housing - it's roll is to measure every ampere of electrical current that flows out-of and into the battery. Without a J367 module SOC can't be calculated. J367 will be installed if your car has start-stop.
    ignore thw yellow gunk - it's an anti-frosting agent that the dealer sprayed onto the negative terminal
    Here is the pics of my batteries Neg terminal No little black boxes and the voltage display wont show even after several trys
    Attached Thumbnails Attached Thumbnails VCDS (VAG-COM) codes and programmable options for Golf Mk7-20191231_115849[1]-jpg   VCDS (VAG-COM) codes and programmable options for Golf Mk7-20191231_115858[1]-jpg
  4. #1724
    Oct 2019
    My mistake I see what you mean now.
    2012 MKVI Golf Comfortline 118 TSI
  5. #1725
    Can someone help me with 3rd brake light tweaks?
    I did some coding (mostly enabling 3rd brake light when boot is open and also for coming/leaving home).
    I tried to enable it for hazard lights but it now is active while using turn signals too.
  6. #1726
    Quote Originally Posted by komoornik View Post
    Why would you want the third brake light on when its pointing to the sky
  7. #1727
    Komoornik: bummer!! If you used my tweak instructions - then I've received many responses confirming that they work OK.
    There are lots of ways that the tweak could go wrong - perhaps the best way to fix the problem is to post-up the FULL Leuchte-set values on your car at present (by which I mean the complete 19 x adaptation channels for Leuchte22BR MA57). You can either copy-and-paste the channels and their values into a post, or include pictures (probably need 3 x pics)
    So any tail-gating birds don't crash into the rear of the car!!!
  8. #1728
    Here are the screenshots.
    BTW is there an adaption channel for cornering lights from the main lamps? I have LED TOP installed.
    Attached Thumbnails Attached Thumbnails VCDS (VAG-COM) codes and programmable options for Golf Mk7-screenshot_2020-01-19-14-50-55-632_com-voltasit-obdeleven-jpg   VCDS (VAG-COM) codes and programmable options for Golf Mk7-screenshot_2020-01-19-14-50-50-809_com-voltasit-obdeleven-jpg
  9. #1729
    try changing Lichtfunkion E22 to "not active"
    not sure what you mean by "cornering lights from the main lamps"?
  10. #1730
    Ok now the 3rd brake light is off. So how to enable the blinking with hazard lights only? I want to keep it on when boot is opened or for coming/leaving home.
    I mean the cornering lights which are turned on when moving a steering wheel (not the fog lights).
