Page 172 of 198 FirstFirst ... 72122162170171172173174182 ... LastLast
Results 1,711 to 1,720 of 1974
  1. #1711
    Jul 2010
    Quote Originally Posted by dArK5HaD0w View Post
    interesting......
    might try this on my Suberb, although it won't b much good given the engine start-stop button in the on the steering wheel column itself.
    nonetheless, give it a crack i shall
    success - its subtle, but a nice touch.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  2. #1712
    Aug 2017
    Uk
    Try setting this adaptation to enabled in 5F infotainment:
    IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B
    ok to me he’s got a low line camera in his car, you gave him options for high line which is kept in the module of the camera (you can change the speed in that module), low line is just basic 12V camera open, 0V camera closed, so although a high line you can use the low line option, the high line you can’t, I can be totally wrong tho
  3. #1713
    Aug 2017
    Uk
    Quote Originally Posted by marsias View Post
    So far i have figure out the Names, i cant find the names of yellow arrows pointed lamps.(s.Pictures)
    Any help from somebody?
    Attachment 47299Attachment 47300
    2 and 4 are the brake lights on my uk car which is 20/21 BR LA71/RC8
    3 is empty and when I looked there was no wire down the right side or LED’s in the cluster (ok it was a few years back so my fog could be on the right not left)
  4. #1714
    Nov 2019
    Italia
    Closing windows & sun roof with 1 click on key remote
    Hi... someone have this coding for Golf MK7.5 2018..!?
    Thanks.
    YouTube
  5. #1715
    ^^^ Assuming that you use VCDS (not difficult to translate to OBD11 speak), try this:
    1. Go to the hex09 module (BCM)
    2. Enter the magic number 31347 as the security code
    3. Go to Adaptation
    4. Navigate to the channels below and change as appropriate:
    Key-fob operation
    ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen > active
    ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen > active
    Sun-roof operation
    ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen > active
    ENG141632-ENG116646-Sunroof-SAD Komfort schliessen > active
    Kessy operation
    IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen > active
    IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen > active
    Enable comfort open/close facility in MENU in the MFD (so you can turn the feature on or off):
    ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar > adjustable
  6. #1716
    Jun 2009
    Western Australia
    I have recently purchased a OBDEleven and one of the tweaks I made was the Battery state of charge. I have noticed that whenever I check it , it always shows that the SOC as 0% . Does that mean that my battery is nearly dead or that the 0% reading is inaccurate?
    Sent from my Pixel 2 XL using Tapatalk
  7. #1717
    Oct 2019
    Are you holding the button down on the key fob? I'm not sure you can just click it.
    2012 MKVI Golf Comfortline 118 TSI
  8. #1718
    Pacific Paradise QLD
    Quote Originally Posted by gh172 View Post
    I have recently purchased a OBDEleven and one of the treaks I made was the Battery state of charge. I have noticed that whenever I check it , it always shows that the SOC as 0% . Does that mean that my battery is nearly dead or that the 0% reading is inaccurate?
    Unless you battery has a module attached to it you cant get that to work.
    What vehicle is it and look to see where the earth point is on the vehicle If its just a bolt on the firewall as in a Tiguan forget it Have tried several times and hardware is just not there
  9. #1719
    3. Go to Adaptation
    Key-fob operation
    Sun-roof operation
    Kessy operation
    Would this also work in a TIguan
    Have slighty different things on 09 like but none of identical to above
    Kessy comfort oeffen Not active
    Kessy comfort shliessen Active
    Kessy Protokollvariant Entry Exit Not active
    Kessy Ruephase Entry Exit Not Active
  10. #1720
    ^ ^^^ this is a pic of the Battery monitor module (J367) that is connected to the negative terminal that Hillbilly refers-to (I think). J367 is basically a coil of wire with a few electronic components embedded in a resin housing - it's roll is to measure every ampere of electrical current that flows out-of and into the battery. Without a J367 module SOC can't be calculated. J367 will be installed if your car has start-stop.
    ignore thw yellow gunk - it's an anti-frosting agent that the dealer sprayed onto the negative terminal
