Page 160 of 198 FirstFirst ... 60110150158159160161162170 ... LastLast
Results 1,591 to 1,600 of 1974
  1. #1591
    Apr 2017
    As Rainesh correctly advises the facility is enabled/disabled by either:
    For mk7 Golf
    In BCM (@ address hex09)> Coding
    For mk7.5
    In BCM (@ address hex09) > Security Access -enter magic number, 31347 > Adaptation> ENG10579-ENG10924-ZV allgemein-ZV_ohne_Safe_Funktion change to "not installed"
    BUT (and there is always a "but"), the Wiring Diagram for those mk7s that are fitted with "deadlocks" (SAFELOCK) appear to have an additional motor in the door lock unit.
    See pic below:
    So - it's unfortunately more than just a coding change
    Sorry for the late reply Don.
    Thank you for your answers.
    I own a Passat and I tried to find those settings in the BCM but Failed.
    Neither yours or Rainesh's showing up in my Passat.
    Neal
  2. #1592
    Aug 2018
    Brasil, SP
    Friends, I have a GTI 2015 Mexican and I am from Brazil, my car when it is stopped the instantaneous consumption of it does not mark the consumption, I have seen that in some cars it is marking the instant consumption per hour. Does anyone know how to empower? type of consumption of 0.8 liters / hour
  3. #1593
    Aug 2018
    Brasil, SP
    Meu amigo, sou do Brasil e tenho um Golf GTI 2015 mexicano de 220 cv que são os mesmos que vão para o Canadá e os Estados Unidos, tentei de todas as maneiras fazer a configuração através do VCDS 12.12.3 a senha é aceita 20103 Eu posso acessar os canais, mas o erro mensagem de erro na entrada, por favor, digite um byte hexadecimal, por exemplo: FF aparece e eu não posso de forma alguma fazer as alterações. Você tem alguma outra dica? É a versão do cabo?
  4. #1594
    Aug 2018
    Brasil, SP
    HELP!!! My friend, I am from Brazil and I have a Golf GTI 2015 Mexican 220 hp that are the same ones that go to Canada and the United States, I tried in all ways to make the configuration through VCDS 12.12.3 the password is accepted 20103 I can access the channels , but the error message error in the input, please enter a hexadecimal byte, for example: FF appears and I can not in any way make the changes. Do you have any other tips? Is it the cable version?
  5. #1595
    Aug 2018
    Brasil, SP
  6. #1596
    Quote Originally Posted by adrianoemp View Post
    hmm.............. "VCDS 12.12.3" ? Sounds like you might be using software that is well out-of-date, or it sounds suspiciously like you might be using a fake cable. If you don't have a fake cable - update the software to the latest version and if you can't (or won't) update the software, stop participating in IP theft!!
  7. #1597
    Aug 2018
    ACT
    Any chance I could have a copy as well please?
    I've managed to fix all but just can't get the indicators to sweep. :'(
    Also my reverse lights are giving me an error too. :'(
  8. #1598
    Japan
    I am not sure this issue has been closed or not for STG17 security code which need to modify instruments illumination for after MY16 model.
    But friend of mine who has MY16 Golf7 found out the security code for STG17 with "47115". If not please tr.
  9. #1599
    ^^^ Zeal-san: Hi
    Just tried your friend's security code (47115) on STG17 on my MY18 Audi A3 (MQB platform like mk7 Golf). Alas no joy!!
  10. #1600
    Japan
    ^^^ Zeal-san: Hi
    Oh. I am sorry this security code did not fit your car.... I am not sure this core is effective for MY16 and after but my friend said the core was works on his car.
