Page 16 of 198 FirstFirst ... 614151617182666116 ... LastLast
Results 151 to 160 of 1974
  1. #151
    Apr 2010
    You won't get any written guarantees, but at the same time I've had a fair amount of warranty work done on my car without any issues raised. Possibly that comes down to how nice your dealer is, but generally they'll only deny a warranty claim if it relates to something you did. i.e. they won't refuse to replace a failed gearbox just because you coded TMC and auto rain-closing windows yourself.
  2. #152
    Mar 2014
    Birmingham UK
    Hello DV52,
    I had noticed from the Ross Tech site, but have not had time to try it.
    Thanks .
  3. #153
    Ryan_R: You are clearly a long time user with considerable experience when it comes to VCDS tweaks. Just out of curiousity, have you ever done a tweak that couldn't be reversed?
    My second question is this:
    Has anyone in VWWatercooled ever considered providing training sessions in VCDS cables? The sort of thing that I'm talking about is a beginner's guide (dummies version). Real basic stuff - just enough to give new users sufficient confidence to take their first fledgling steps. I'm very grateful for your guidance in this forum when I first started (still got an awful lot to learn), but a formal class would have been advantageous (I think).
    Not sure how (or, if) this would work, but one of the sponsors (or a local distributor for Mr Ross's products) could provide support (perhaps in the form of a venue and equipment) and some of the more experienced guys could take the class. These classes would be a good advertising medium for future VCDS sales and they would add kudos to the reputation of this forum. VWWatercooled could charge a modest fee to cover their costs. Classes would vary depending on the State where they were held and dependant on the local support that was available. Classes would only run if there was sufficient demand in the State (i.e. attendance would be through formal bookings only - not sure if attendance should be restricted to forum members).
    Anyhow, just a thought!
  4. #154
    Apr 2010
    As long as you document what the original values were you can change them back.
    You can do damage by messing around in the (ironically named) Basic Settings section of VCDS if you don't know what you're doing. As for training and confidence the Mk6 Golf VCDS thread is designed to take care of that. You should use it as a template for the Mk7 subforum and make your own thread with everything a new user needs in the first post.
  5. #155
    Dec 2012
    Melbourne Vic
    Thanks guys, I guess a bit of convincing will help. There are some genuine benefits to doing these minute changes. Makes the car just a bit more perfect for me.
  6. #156
    Apr 2014
    Hi!
    Does anyone know if there is a code to display in the driving data or similar menu in the dash whether the brake lights are on? I'm a nerd. I want to see when the car coasts and when it uses the brakes when the cruise control is on
    Cheers,
    Greg
    MY14 Golf Wagon Highline 1.4L TSI 103, Limestone Grey Metallic, Roof, Leather, DAC.
  7. #157
    Aug 2011
    Quote Originally Posted by lambertia View Post
    Hi!
    Cheers,
    Very unlikely, but if you do it at night you'll probably be able to see to top brake light in the rear hatch light up in the rear view mirror?
  8. #158
    Hi!
    Cheers,
    Lambertia: The only VCDS tweak that enven remotely comes close (and it's not close at all) is a tweak that uses the tail lights as a brake light (it's on the Stemei.di site).
    I'm not sure how much effort you want to put into this - but just thinking laterally, you could replace one of the barke lights with an LED version (without CANBUS correction) and then get feedback via the lamp failure message on the dash.
  9. #159
    May 2014
    I'm a little confused about the voice control offered as an accessory vs the voice control for phone (or is it the same?)
    I know Australian vw's have to have it enabled at the dealer but people were uncertain if it is a vcds change or software update.
    I wan't to be able to use my sterring wheel to activate voice control (either siri or my BT) to search for a contact and make calls.
    The following page has vcds settings to activate voice control. Is it applicable to the MK7?
    Bluetooth-9w7 module voice control retrofit, swap, install, and FAQ | VW TDI forum, Audi, Porsche, and Chevy Cruze diesel forum
    I have the dealer changing my soundaktor when I collect the car this thurs so I'd be keen to have this switched on if it's possible .
  10. #160
    Apr 2010
    The above link is for the Mk6 Golf and equivalents (Tiguan, Jetta, etc) where the car wasn't optioned with Bluetooth. In the case of the Mk6 voice control is a fairly simple VCDS tweak assuming everything is wired up correctly. I'm not sure that a definitive DIY outcome has been reached for the Mk7 yet, so you may want to ask your dealer at this stage. While it is handy for some, most agree it's not worth spending hundreds of dollars on, especially if you're not the patient type (you need to speak slow and clearly, a bit like a robot).
