Page 157 of 198 FirstFirst ... 57107147155156157158159167 ... LastLast
Results 1,561 to 1,570 of 1974
  1. #1561
    Quote Originally Posted by maca View Post
    I feel like an absolute noob with this. I managed to activate the alarm chirp on lock and the DRL control in the vehicle settings, but I can’t seem to deactivate the DRL wink when the turn signals activate.
    maca: Being able to deactivate the DRL wink facility really depends on the module arrangement in your car. In recent model mk7s that have new left and right side LCMs (Light Control Modules) @ address hex29 & hex39, it's not possible to alter much at all on the DRLs.
  2. #1562
    Dec 2010
    Hey guys - anybody know if it's possible to change (or more specifically - set) a delay before auto hold kicks in? In the Arteon, pretty much the split second I come to a stop, auto hold engages.
    What I would like to do is have it so say... it only comes on if I've been at a dead stop for 2secs+
    My car: MY18 Arteon
    My car #2: MY22 Volvo XC40 Pure Electric
    Her car: MY22 Skoda Octavia Limited Edition Wagon
  3. #1563
    Auto Hold depends on a brake force, use the pedal gently.
    And it still works much better then in Audi A4 B8 - it tends to jerk because there it activates too quickly.
  4. #1564
    Apr 2018
    Quote Originally Posted by DreamensioN View Post
    Yes, I'd like to change this as well!
    While at it, is it possible to change the Auto Start Stop Engine in the same way?
    On a separate note, it would be amazing if the Driving Mode had a memory. For example, when in Comfort the dash/cluster showed the map with the range and efficiency but when in Sport the dash showed Gear and Speed. Probably too much to ask.
    Arteon & T-Roc
  5. #1565
    Dream..: You could try something like this:
    Select ABS Brake module @ address hex03
    Select the adaptation channel Dynamic starting assist
    Select one of the following settings "Early", "Normal" (default) or "Late"
  6. #1566
    Dec 2010
    Thanks for this Don.
    I did try this today but it made no difference to the auto hold. Not that I could tell anyway. To be honest, I'm not even sure if I detected any difference with anything, so I put it back to the default Normal setting.
    My car: MY18 Arteon
  7. #1567
    Apr 2017
    belgrave victoria
    You can't deactivate start/stop with obd11
    You can get a kufatech module for about 70 bucks that will do it tho
    Have done it on my alltrack works great
  8. #1568
    Sep 2012
    Quote Originally Posted by Kachingg View Post
    If you had OBD11 Pro couldn't you just manually use the long coding to set the start/stop voltage threshold?
    MY13 Golf GTI DSG (SOLD)| Candy White | 18" Detroits | Bi-Xenon Headlights | Street Guardian SG9665C
    MY18 Golf R DSG | Indium Grey | 19" Spielbergs | DAP | Sunroof | Viofo A119v2 (front) | BlueSkySea B1W (rear)
    Micro-CAN VCDS
  9. #1569
    Apr 2018
    Do you clean out your VAG before a service? Making it look untouched.
    What I mean to say, do you reset your code changes before a service at a dealer?
    Arteon & T-Roc
  10. #1570
    Nov 2017
    Coffs Harbour NSW
    Quote Originally Posted by HiddenTaco View Post
    I'd love this, it does this for the Infotainment system, but not the active info dash. I guess once more cars get the feature standard we might see it.
    I'd love to me able to add quick toggles to the DAP button. I usually toggle Adaptive Lane assist on and off, but I rarely completely disable it. I haven't been able to find any lists to modify, but my gf has banned me from OBD11.
    Good question.
    I'm thinking I'll undo the cosmetic changes like Fog with DRL and TP and it's right there saying No TP
