Page 151 of 198 FirstFirst ... 51101141149150151152153161 ... LastLast
Results 1,501 to 1,510 of 1974
  1. #1501
    Sep 2012
    ^^^ many thanks - seems like later model mk7s do indeed have the counter!
    Did a few launches over the weekend and can report the counter does indeed increment:
    MY13 Golf GTI DSG (SOLD)| Candy White | 18" Detroits | Bi-Xenon Headlights | Street Guardian SG9665C
    MY18 Golf R DSG | Indium Grey | 19" Spielbergs | DAP | Sunroof | Viofo A119v2 (front) | BlueSkySea B1W (rear)
    Micro-CAN VCDS
  2. #1502
    The happy maximum was 200
    200 Launch Maximum Reached - Launch Control No Longer Functional
    A mate with an S3 said he got an mild grilling at the Audi Centre when he recorded 16 in one year.
    Quote Originally Posted by Kevlarman View Post
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
  3. #1503
    How to enable at the same time main beam/drl and fog lights for CH/LH?
  4. #1504
    Nov 2017
    Coffs Harbour NSW
    Fog and DRL would look cool for CH/LH. I set mine to run the Fogs with DRL during the day. Fogs shut off at night when the mains come on. Can still use the switch to force the fogs on.
    Looks cool, being LED the fogs are fairly dim during the day, but adds a nice subtle glow to the front grill.
  5. #1505
    Ok got both main beam and fog lights as CH/LH - I've set the coming home option to fog lights and manually used LC5 C6 and RB1 C7 to set them as CH/LH.
    Anyone knows which channel is used for cornering lamps in headlights? I would like to set them as CH/LH too.
  6. #1506
    Quote Originally Posted by komoornik View Post
    hmm...... I don't think that it's possible to use Leuchte -programming to alter the cornering lights in the headlamp fittings. The operation of these lamps is controlled by the range-control modules (@ address hex 55) - I think. Happy to be corrected
  7. #1507
    Mar 2018
    Romania
    Hi, I have a problem on my golf 7 that I bought 2 days ago, and I found out that my high beam is not working, in my dashboard the blue indicator is lighting OK but no high beam, the car has factory Bi-Xenon and adaptive light with automatic high beam and also automatic light is not working.
    I attach the scan of my car and I hope someone will help my, I think that is a problem from coding because the low beam is working ok.
    Thank you!
    Chassis Type: AU (5Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 55 5F 69 A5
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: Malfunction 0010
    5F-Information Electr. -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    A5-Frt Sens. Drv. Assist -- Status: OK 0000
    Address 01: Engine (J623-CRBC) Labels: 04L-907-309-V1.clb
    Part No SW: 04L 906 021 DT HW: 04L 907 309 D
    Component: R4 2,0L EDC H22 5520
    Revision: 83H22---
    Coding: 111D0032047405082000
    Shop #: WSC 00028 028 00075
    ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
    ROD: EV_ECM20TDI01104L906021DT_VW37.rod
    VCID: 7AE3E533ACDFA05251A494D-802E
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
    Part No SW: 5Q0 937 086 L HW: 5Q0 937 086 L
    Component: BCM PQ37BOSCH 020 0078
    Revision: -------- Serial number: 86582709130972
    Coding: 00021B46C2C122FB0BA44080B11C0708100A00000000000000 0000000000
    Shop #: WSC 00028 028 00024
    ASAM Dataset: EV_BodyContrModul1UDSBosc 011005
    ROD: EV_BCMBOSCH_AU37.rod
    VCID: 439D58D79B95219A42C2311-8016
    Slave 1:
    Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
    Component: WWS 130926 042 0551
    Serial number: 130927211249
    Coding: 0F4DDD
    Slave 2:
    Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
    Component: RLFS 024 0042
    Serial number: Y13M10D08H23M12S50S1
    Coding: 00A8DD
    Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
    Component: Sensor, DWA 005 0315
    Serial number: 000000000ZY132330SYY
    Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
    Component: Sirene, DWA 004 0311
    Serial number: 00000000000027950607
    Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
    Part No SW: 5Q0 919 298 A HW: 5Q0 919 298
    Component: PARKHILFE PLA 011 0029
    Revision: -------- Serial number: 61131326301384
    Coding: 0031161151
    ASAM Dataset: EV_EPHVA2CAU3700000 003014
    ROD: EV_EPHVA2CAU3700000_VW37.rod
    VCID: 3D692E2FFD71576A3406779-8068
    Address 13: Auto Dist. Reg (J42 Labels: 5Q0-907-572.clb
    Part No SW: 5Q0 907 572 A HW: 5Q0 907 572 A
    Component: ACC Bosch MQB H04 0150
    Serial number: 06101376510056
    Coding: 001C1D00FE0339
    ASAM Dataset: EV_ACCMRRBoschVW372 001013
    ROD: EV_ACCMRRBoschVW372_AU37.rod
    VCID: 3579360FC5418F2AFC769F9-8060
    Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
    Part No SW: 5Q0 953 521 R HW: 5Q0 953 569 A
    Component: Lenks.Modul 075 0085
    Revision: FF026026 Serial number: 20131003400224
    Coding: 0C00
    ASAM Dataset: EV_SMLSVALEOMQB 001011
    ROD: EV_SMLSVALEOMQB.rod
    VCID: 419152DF8189338A50EE1B9-8014
    Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
    Part No SW: 5G0 920 861 A HW: 5G0 920 861 A
    Component: KOMBI 252 2210
    Coding: 07A411086F94000801886A03040000
    ASAM Dataset: EV_DashBoardVDDMQBAB 008031
    ROD: EV_DashBoardVDDMQBAB_AU37.rod
    VCID: 2745EC470FEDEDBA7EEA651-8072
    Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
    Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 M
    Component: GW MQB High 212 2147
    Revision: -------- Serial number: 24091310801455
    Coding: 030100340B087300EF00065E1C0F0001000100000000000000 0000000000
    ASAM Dataset: EV_GatewConti 009011
    ROD: EV_GatewConti.rod
    VCID: 3B6D2037E365595A0A32591-806E
    Alternator:
    Multifunction unit control module:
    Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K
    Component: E221__MFL-DC1 H15 0038
    Serial number: 27130001561400033391
    Coding: 2DFFFF
    Battery Monitoring Control Module:
    Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
    Component: J367-BDMHella H03 8042
    Serial number: 2624821403
    Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
    Part No SW: 5Q4 959 593 HW: 5Q4 959 593
    Component: TSG FS 007 0006
    Serial number: 0000076967124
    Coding: 003A02208C00028000001000
    ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
    ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
    VCID: 02139DD3C40FE8920974CCD-8056
    Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A
    Component: Fond FHSG DRV 007 0002
    Serial number: 00000000000002923623
    Coding: 010000
    Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
    Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
    Component: EPS_MQB_ZFLS 123 1043
    Coding: 1303
    ASAM Dataset: EV_SteerAssisMQB 010031
    ROD: EV_SteerAssisMQB.rod
    Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
    Part No SW: 5Q4 959 592 HW: 5Q4 959 592
    Component: TSG BFS 007 0006
    Serial number: 0000077829631
    Coding: 003A00208E00028000801000
    ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
    ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
    VCID: 011192DFC109F38A106EDB9-8054
    Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A
    Component: Fond FHSG PSG 007 0002
    Serial number: 00000000000002934697
    Coding: 090000
    Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
    Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
    Component: AFS-ECU H07 0080
    Revision: -------- Serial number: --------------
    Coding: 029A00104F000200
    ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
    ROD: EV_HeadlRegulVWAFS_SE26.rod
    Subsystem 1 - Part No SW: 3D0 941 329 A HW: 3D0 941 329 A Labels: 3D0-941-329.CLB
    Component: LeiMo links H05 0012
    Coding: 900000
    Subsystem 2 - Part No SW: 3D0 941 329 A HW: 3D0 941 329 A Labels: 3D0-941-329.CLB
    Component: LeiMo rechts H05 0012
    Coding: 900000
    1 Fault Found:
    13705479 - Databus
    U1121 00 [009] - Missing Message
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 253
    Mileage: 193703 km
    Date: 2018.03.15
    Time: 17:20:32
    Address 5F: Information Electr. (J794) Labels: None
    Part No SW: 5G0 035 874 HW: 5G0 035 874
    Component: MU-S-ND-ER 040 0421
    Serial number: V7F00610132267
    Coding: 02730201FF00000021111201002800001F0100140100010045
    ASAM Dataset: EV_MUStd4CPASE 002039
    ROD: EV_MUStd4CPASE_SK37.rod
    VCID: 67C5AC47CF6D2DBABE6AA51-8032
    Media Player Position 1:
    Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
    Component: ABT_Std_Nav H51 0022
    Serial number: VWZ8Z9NJ901M7G
    Address A5: Frt Sens. Drv. Assist (R242) Labels: 5Q0-980-653.clb
    Part No SW: 5Q0 980 653 E HW: 5Q0 980 653
    Component: MQB_MFK H05 0051
    Serial number: 00000125971
    Coding: 0101010001020304000400000100000101
    ASAM Dataset: EV_MFKBoschAU370 001001
    ROD: EV_MFKBoschAU370_AU37.rod
    VCID: 3A632533EC5F6052112454D-806E
  8. #1508
    Dec 2010
    Hey guys - over in the Passat section - someone posted this: VCDS Tweaks
    Basically in that post, they talk about how they increased the voltage of the DRL's and headlights from 10v to 12v and it's made a "world of difference". Unfortunately they're unwilling to share this information (for free). This was posted a little while ago, so I'm wondering if anybody has managed to figure it out in what section it is?
    My car: MY18 Arteon
    My car #2: MY22 Volvo XC40 Pure Electric
    Her car: MY22 Skoda Octavia Limited Edition Wagon
  9. #1509
    Dec 2010
    Quote Originally Posted by DreamensioN View Post
    You know what...never mind - I think this is to do with halogen globes, and not LED's. I thought I could increase the intensity of my LED lights, but I don't think this is the way to go about it. I'll keep digging on this.
    As a side note, I've got a kick-to-open bootlid/tailgate. Does anybody know if it's possible to do "kick-to-close" ? I found a VCDS setting for a Skoda Octavia, but in my model 6D-Trunk Elect, I don't have the option to close on kick.
    I'm just hoping this is possible through VCDS and doesn't need the VCP tool.
    My car: MY18 Arteon
  10. #1510
    Dec 2017
    QLD Australia
    If you press the rain light feature next to light switch it turns on extra lighting almost like driving light without blinding other cars in front or oncomming
