Page 148 of 198 FirstFirst ... 4898138146147148149150158 ... LastLast
Results 1,471 to 1,480 of 1974
  1. #1471
    Anyone enabled this...lock car with engine running...
    KESSY: Lock Car While Running
    Description: this allows you to to start your car with KESSY, then get out with the key, and lock the car with the remote
    Check bit 2 of byte 4 in Central Electronics Long Coding Helper
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
  2. #1472
    Jan 2018
    Chiapas
    Quote Originally Posted by tapachula View Post
    New with OBD11, I have successfully codified almost everything, I have read all the pages of this forum and others, and as many I would like to thank the collaboration of DV52 and others that their contributions are remarkable.
    I wonder if someone could disable the legend of care when reversing. I read it in another site but it does not accept the access code, it's obviously wrong because it's out of range.
    *I speak Spanish, sorry my english
    https://imgur.com/a/1rhYg
    Hi Don, thanks in fact I started yesterday to test your list of codes, I update you in case of succeed.
    @Kevlarman, its correct, tweak is from Autoinstruct site. All others codings are correct except this.
  3. #1473
    Enable FOB with car running works great.
    You can use the remote within the car to release the hatch, and my favourite, you can leave the engine running, get out the car, and lock it.
  4. #1474
    Jun 2017
    San Francisco, CA USA
    My mods - 2015 Mk7 (NA, 2 door, SE, lighting package with bi-xenons)
    Big thanks to @DV52 for great explanations and details of "dynamic turn signal mode".
    CHMSL alternate blink with emergency flasher (solid on brake)
    Dyn. turn signal modes-Warnblinken_Zuendung_AUS == active
    Dyn. turn signal modes-Warnblinken_Zuendung_EIN == active
    (4)-Leuchte22BR LA57-Lichtfunktion A 22 == Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken
    (5)-Leuchte22BR LA57-Lichtfunktion B 22 == not active
    (-Leuchte22BR LA57-Lichtfunktion C 22 == Blinken links Hellphase
    (9)-Leuchte22BR LA57-Lichtfunktion D 22 == Blinken rechts Hellphase
    (10)-Leuchte22BR LA57-Dimmwert CD 22 == 0
    (11)-Leuchte22BR LA57-Dimming Direction CD 22 == minimize
    (12)-Leuchte22BR LA57-Lichtfunktion E 22 == Brake lights
    (13)-Leuchte22BR LA57-Lichtfunktion F 22 == not active
    (14)-Leuchte22BR LA57-Dimmwert EF 22 == 100
    Inner Brake/Turn Signals
    (1)-Leuchte23SL HLC10-Lasttyp 23 == 14 - kombinierte Blink- Bremsleuchten
    (4)-Leuchte23SL HLC10-Lichtfunktion A 23 == Brake light (Bremslicht)
    (5)-Leuchte23SL HLC10-Lichtfunktion B 23 == Blinken links Hellphase
    (6)-Leuchte23SL HLC10-Dimmwert AB == 23 100
    (-Leuchte23SL HLC10-Lichtfunktion C 23 == Blinken links Dunkelphase
    (11)-Leuchte23SL HLC10-Dimming Direction CD 23 == minimize
    (12)-Leuchte23SL HLC10-Lichtfunktion E 23 == Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
    (14)-Leuchte23SL HLC10-Dimmwert EF 23 == 28
    (1)-Leuchte24SL HRA65-Lasttyp 24 == 14 - kombinierte Blink- Bremsleuchten
    (4)-Leuchte24SL HRA65-Lichtfunktion A 24 == Brake light (Bremslicht)
    (5)-Leuchte24SL HRA65-Lichtfunktion B 24 == Blinken rechts Hellphase
    (6)-Leuchte24SL HRA65-Dimmwert AB 24 == 100
    (-Leuchte24SL HRA65-Lichtfunktion C 24 == Blinken rechts Dunkelphase
    (11)-Leuchte24SL HRA65-Dimming Direction CD 24 == minimize
    (12)-Leuchte24SL HRA65-Lichtfunktion E 24 == Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
    (14)-Leuchte24SL HRA65-Dimmwert EF 24 == 28
    Single Side Parking Light
    (4)-Driving light and parking light-Parklicht ueber LSS aktiviert == one-sided
    (13)-Leuchte20BR LA71-Lichtfunktion F 20 == Parklicht links (beidseitiges Parklicht aktiviert li & re)
    (13)-Leuchte21BR RC8-Lichtfunktion F 21 == Parking light right
    DRLs stay on with turn signals
    (-Leuchte3SL VRB21-Lichtfunktion C 3 == Not Active
    (-Leuchte5 TFL RB32-Lichtfunktion C 5 == Not Active
    (-Leuchte2SL VLB10-Lichtfunktion C 2 == Not Active
    (-Leuchte4TFL LB4-Lichtfunktion C 4 == Not Active
    Window/Sunroof Open/Close on remote
    See MQB Platform tweaks - Page 2
    2-Access control 2- Comfort opening == active
    3- access control 3- Comfort closing == active
    7- access control 2- Funk Komfort oeffnen == active
    6- access control 2- Funk Komfort schilessen == active
    27- access control 2- Menuesteuerung Komfortbedienung einstellbar == adjustable
    20- access control 2-Kessy Komfort schilessen == active
    10- access control 2 - SAD Richtung Komfortöffnen auswählen or Access control select comfort opening direction == (open or tilting)
    Car menu: comfort opening = on
  5. #1475
    Question
    Quote Originally Posted by sVWatt View Post
    sVWatt: I think that you might be referring to the older version Golf - perhaps this:
    For the mk7, this function is enabled via an adaptation channel change as follows:
    1. For older BCMs, IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein > active
    2. For newer BCMs ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein > active
    Of course, you will need to use the venerable magic number 31347
  6. #1476
    Hi Don
    I was adventurous and nailed this one by myself last week.
    You are right though, the setting change enables the key to work inside the car and outside the car with the engine running.
  7. #1477
    Sep 2012
    Hi Don
    Just curious: in what circumstances would you need to keep the engine running with the doors locked? I suppose the only thing I can think of is leaving pets/kids/partner in the car while you duck out to the shops.
    I believe some states have laws against leaving a running vehicle "unattended."
    MY13 Golf GTI DSG (SOLD)| Candy White | 18" Detroits | Bi-Xenon Headlights | Street Guardian SG9665C
    MY18 Golf R DSG | Indium Grey | 19" Spielbergs | DAP | Sunroof | Viofo A119v2 (front) | BlueSkySea B1W (rear)
    Micro-CAN VCDS
  8. #1478
    Quote Originally Posted by Kevlarman View Post
    Two benefits to me personally...
    Release of hatch from within car.
    Defrost the Canberra frosty mornings car, without anyone desiring to drive off in my car 😎
  9. #1479
    Jan 2018
    Chiapas
    tapachula: hi . I have not seen your tweak instruction before. I've also not seen 71679 used as a security code in the ABS module @ address hex03.
    I have started a list of security codes HERE which you are welcome to try on your tweak instructions.
    Please be aware that control modules will lock-out if you enter the wrong security code. If this happens, the lock-out time can be upward of 20 minutes and the time is measured with the ignition switched-on
    Please provide feedback if your tweak instructions are successful
    I can confirm that none of the access codes works for this specific tweak.
    GOLF Highline 2016 with ParkAssist/Halogen headlights
  10. #1480
    Dec 2015
    NSW
    Hey Don
    I do like your old tweak for incandescent tails at post #454 (page 46) of this thread.
    Should this same tweak work with LED tails on Mk 7 R, or is there somethings different needed ?
    I tried searching the rest of this thread, but with #1479 posts and counting, its a small needle in my haystack.
    TIA's
    Current : 2017 Mk7 Golf R (most options) || 2012 Golf Mk6 TDi (few options)
    Gone : 2004 Bora V6 4Motion (few klms, all options)
