Page 144 of 198 FirstFirst ... 4494134142143144145146154194 ... LastLast
Results 1,431 to 1,440 of 1974
  1. #1431
    Gamester- not sure this helps:
    Example 1
    System description: ESC
    Software number: 3Q0907379AB
    Software version: 0723
    Hardware number: 3Q0907379G
    Hardware version: H42
    Serial number: 62615000000403
    ODX name: EV_Brake1UDSContiMK100IPB
    Long coding: 20EE629214210973007F060241C9240446289000608224F2D4 61F0024006
    Example 2
    Serial number: 62685000001022
    Long coding: 01FA93A1542429730777070741C76980C92A94E0E08296F718 425078C208
    Example 3
    Serial number: 62115000000629
    ODX version: 034036
    Long coding: 04FA6AA124210971007B020481C5292056249000408194B416 435052C082
    Example 4
    Adressword : 03 (Bremsenelektronik} - J104 ESC
    VAG Nr. SW: 3Q0907379AB HW: 3Q0907379G
    SW Version 0723
    # Codierung 18EE62923420096D007B060641C42918462C9000608294F436 615080C023
    And the comparison looks like this:
  2. #1432
    Jan 2018
    Kiev
    Thanks!
    Can you specify Car, engine and transmission?
    Also I think that coding is similar for all H42 ABS and may be even similar to H31. Probably you have other H42 ABS coding.
    As I know byte0 is define car type.
    01 - VW Golf 7
    04 - VW Golf 7 Variant
    1A - Skoda Octavia A7
    1D - Skoda Superb III
    Byte4 is a front brakes:
    14 - 270 mm
    24- 288 mm
    34 - 312 mm
    54 - 340 mm
    Byte14 is rear brakes:
    25 - 253 mm
    29 - 272 mm
    68 - 310 mm
    Byte17 is main brakes cylinder
    24 - for cars <=110 kWt
    28 - for cars 1.2TSI
    2C - 135/155 kWt
    2A - >168 kWt
    Bytes 5,7,9,11,13 is calculated from VIN and can be taken from old ABS coding.
    here is calculator to calculate this bytes from VIN
    Vagflash
  3. #1433
    OBDeleven’d recently and looking for advice on enabling Pace-Car indicators on my 7.5.
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
  4. #1434
    Dec 2015
    NSW
    Quote Originally Posted by sVWatt View Post
    See Post # 558 on this page
    VCDS (VAG-COM) codes and programmable options for Golf Mk7
    There's a nice video, and instructions.
    Yes, it did take a bit of searching to find this good info in the forum. A small shame we don't have an index or master list for all the tweaks.
    But wait, I just found the index at MkVII VCDS Tweak - Reference thread
    and it references the very same post I found too.
    I used the following search : site://vwwatercooled.com.au Leuchte16BLK
    You're welcome.
  5. #1435
    Nov 2017
    Coffs Harbour NSW
    Do the MK7.5 indicators support pace car mode?
  6. #1436
    crainger: excellent question - I'm not sure but I doubt it!!
  7. #1437
    Aug 2017
    Uk
    Difference between mk7 and mk7.5(standard) indicators
  8. #1438
    Thanks guys,
    Only just walked out to my car this morning and noticed the difference. If it can be done, I’m sure the Don would know. I’ll move onto coding for close on rain... 😀
    Quote Originally Posted by Jap View Post
  9. #1439
    Aug 2017
    Uk
    Thanks guys,
    Only just walked out to my car this morning and noticed the difference. If it can be done, I’m sure the Don would know. I’ll move onto coding for close on rain... 
    remember on the 7.5 there’s no long coding in the central electronics, but there is a subsystem you need to long code instead (rhls or something like that)and the access control 2 adaptions are under zv_komfort
  10. #1440
    One more question;
    What’s the long coding for disabling the overtaking in the left lane...my car slows down when I merge into traffic, and won’t go past a slow moving car iif it’s in the outside lane....
