Page 143 of 198 FirstFirst ... 4393133141142143144145153193 ... LastLast
Results 1,421 to 1,430 of 1974
  1. #1421
    Jan 2018
    Quote Originally Posted by sVWatt View Post
    Anyone have direct experience of Carista?
    Carista OBD2 App | Diagnose, customize and service your car
    I’m an Apple addict, so it would be easier for me, than say the OBDEleven, but only if all the functionality is there.
    Any users out there?
    I'm wanting to check my Launch Control Count and only use Macs. Willing to be a test dummy.
    Do you know if below is everything I need (site links to Amazon for purchase - $60AUD delivered). Apologies for being so green on this!
    Carista OBD2 Bluetooth Adapter, Scanner and App for iOS and Android: Diagnose, Customize and Service your Audi, VW, Toyota, Lexus, BMW, Mini or Scion with dealer level technology
    $39.99
    Quantity: 1 Changequantity of Carista OBD2 Bluetooth Adapter, Scanner and App for iOS and Android: Diagnose, Customize and Service your Audi, VW, Toyota, Lexus, BMW, Mini or Scion with dealer level technology from 1
    Sold by: Prizmos Ltd.
  2. #1422
    Quote Originally Posted by BIGDOG View Post
    BIGDOG: Launch control count on a mk7 Golf? Interesting thing to do - I didn't think that MQB vehicles had this facility! Eager to hear of your experience (ELM chip based devices tend to be not as "intimate" with their host OBD ports)
  3. #1423
    Dec 2010
    Helensburgh
    The new Tiguan has launch control but why is one of life's big mysteries.
  4. #1424
    Jan 2018
    There were some 'surprise' dealer K's on my new Golf hence my curiosity on launches. Have spoken to my mechanic and he believes he can access the count. Will know next week when I catch up with him.
  5. #1425
    Feedback: downloaded the iOS app today and trialled it on my 7.5 - first it runs a diagnostic check (no faults), then it offers options which it knows will work on your model.
    I enabled fan speed on auto, and remember driver and passenger heated seat settings. Could not get rain close to stay ‘on’, but have msg the developer for feedback.
    No long coding, but easy user interface....
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
  6. #1426
    Dec 2015
    NSW
    Can it turn off the fake engine noise, aka soundaktor ?
  7. #1427
    Is there some way to dim the 7.5 led front fog lights? I was planning to enable the fogs so that they are constantly on, switch in Auto position. But would like them to be more dimmer so that they do not attract the police. Only when I pull the light switch for the fogs to be normally on, then they would be full brightness.
    Or would it be easier for this to work if it is only like this if the light switch is fully turned to right.
  8. #1428
    Quote Originally Posted by bgroper View Post
    Didn’t see that option listed.
  9. #1429
    Quote Originally Posted by UserName123 View Post
    hmm........ you could add the "Terminal 15" Leuchte-command to an unused Alpha channel and then use a lower value in the associated Dimmwert channel ("Terminal 15" is the function of turning-on the ignition) - but the Leuchte-sets for the two front fog lights needs to be active.
    If the setting for ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 on your mk7.5 is NOT not active, try this:
    Go to the BCM (@ address hex09) - then enter the magic number 31347 as the security code:
    Right-side front fog-light
    ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 change to Klemme 15 mit Nachlauf bis Fahrzeugstillstand
    ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 change to 50 (or, any value you want)
    Left-side front fog-light
    ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 change to Klemme 15 mit Nachlauf bis Fahrzeugstillstand
    ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 change to 50 (or, any value you want)
    As explanation, according to Mr Google, Klemme 15 mit Nachlauf bis Fahrzeugstillstand translates to Terminal 15 with overrun until vehicle standstill - so the fog-lights will (should?) illuminate whenever the ignition is turned-on, or the vehicle rolls (without ignition-on). The suggested changes won't (shouldn't?) affect the normal operation or the illumination level of the fog-light - when the center part of the rotary light switch is pulled-out.
    Of course, I make no judgement regarding the suitability of the change to the fog-light operation with the prevailing road laws in your part of the world (I've never been to Hell -but I suspect that I will be a resident there after I pass). You should satisfy yourself about this matter before implementing the tweak
    Finally, if you do try this untested tweak - please share your observations
    PS:Is there a road-sign as you approach your place of residence saying "Abandon hope all ye who enter here"?
  10. #1430
    Jan 2018
    Kiev
    zloybob
    Information from my database below
    ;SW:3Q0-907-379-F HW:3Q0-907-379-F --- ABS Brakes
    Coding:01FA93A13421097407770603C1C8A980C92C90E0608 395F514605078C006
    EV_Brake1UDSContiMK100IPB
    ;SW:3Q0-907-379-P HW:3Q0-907-379-C --- ABS Brakes
    Coding:04FA6AA12420096E0078020981C4252056249000408 1A4B210630050C002
    ;EV_Brake1UDSContiMK100ESP
    SW:3Q0-907-379-R HW:3Q0-907-379-G --- ABS Brakes
    Coding:04FA8AA12421116C077C060941CB2920512488E0608 294F31822503AC282
    ;SW:3Q0-907-379-T HW:3Q0-907-379-C --- ABS Brakes
    Coding:01FA6BA154200971007C020941C76880D62A9000408 216B6144350D3C089
    Coding:01FA6AA1242509720078020081CC298056249000408 194B410430050C002
    I had changed my ABS from 29 bytes 5Q0907379AC to 3Q0907379AB
    my old ABS coding
    01FA6AA120211275037C060601C32980560448C0608094F3142A5038C1
    my new ABS coding
    01FA6AA114212975077C060641C32580562894E0608294F314225078C102
    But i think it is not fully correct
    at least Brakes specified incorrectly in byte 4 and 14.
    I think the correct values are 24 in byte 4 and 29 in byte 14. But ABS did not accept such changes.
    is there any one who could help me with proper coding?
    My car is VW golf 7, 1.4TSI 140Hp, DSG7. Front brakes are 288mm, rear brakes 272 mm.
