Thanks for this and all other input. I seem to have missed the G & H adaptions
Cheers MF
btw I am actually a skippy transplant
Printable View
I like to keep my menus and displays trimmed down (ie minimalist) to just the info and details I'm interested in. Less is more.
Selfish perhaps, but hey, its my car.
Thanks for any tips or clues for how to delete the compass heading from the MFD (display between the tacho and speedo) in a Mk7 R.
^^^^Yes, you are correct - it is your car and you're perfectly entitled to be rid of that annoying direction display.
Mine is a wild guess - but the only adaptation channel that I can find on my car that is remotely related to "compass" and that is not "not active" is IDE04307-ENG117733-Vehicle function list BAP-compass_0x15_msg_bus. This channel has a factory setting Databus Infotainment. Might be worth experimenting with this - as I said, entirely untested suggestion
Has anyone with a 7.5 been bothered by the engine stop/start restarting when the car infront of you creeps forward in traffic? I find this extremely frustrating as I avoid inching forward in traffic to prevent wear on my DQ200. I've looked around in the adaptions for the ACC and front sensor but haven't found a way to turn it off - has anyone found a way to remove it?
Dark: Hi. Good question - to which the answer is maybe!
Although the Passat B8 and the Golf mk7 share the same MQB build platform and despite the fact that the Body Control Module (BCM) in both models use "Leuchte-sets" to control exterior lighting, the BCM pin configuration is different.
If you look at my instructions, you will see that I modify Leuchte17TFL R BLK BLK SRB3TFL R SR KC3 and Leuchte16BLK SLB35BLK SL KC9. The designations C3 and C9 mean that these Leuchte-sets control the lamps that are wired to pin #3 and pin#9 of the C connector on the BCM. On a mk7 Golf, these pins are wired to the inner LED turn signal lamp.
If you look at the admap HERE which is from the BCM of a Passat B8, you will see that the KC3 and KC9 Leutche-sets don't function as turn signals (they operate as Parking Lights).
I'm not sure if the 2 x Leuchte-sets above actually control the left/right inner rear lamps on a tail-light for a Passat B8. But, if you are prepared to participate in a little experimentation, I am willing to modify my instructions to suit your car.
What I need you to do is the following:
- Turn-on the Parking lights and confirm that the 2 x inner rear tail-light lamps illuminate. Turn-off the Parking lights
- Select 09 - Central Electr control module
- Select Security Access - 16 from the "Open Controller" screen
- Enter the magic number 31347 and return to the "Open Controller" screen
- Select Adaptation - 10 from the "Open Controller" screen
- Enter "Leuchte16BLK" into the search box and select Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16
- Change the setting from 100 (or 127) to 0.
- Turn-on the Parking lights - the left inner rear tail-light should not illuminate. Turn-off the Parking lights
- Restore the original setting to Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16
- Enter "Leuchte17TFL" into the search box and select Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17
- Change the setting from 127 to 0.
- Turn-on the Parking lights - the right inner rear tail-light should not illuminate. Turn-off the Parking lights
- Restore the original setting to Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17
- Report observations here
Hey Don
You seem to be the resident forum expert with the codings.
I'm irritated by the nag screen which appears each time I launch the Navigation app in my Mk 7 R.
Seems to come each first time Nav is launched in each driving session.
"For your own safety, please follow traffic regulations at all times." A pointless PITA.
Is there some simple code to permanently turn off this unwanted nag pop-up ?
TIA's
VCDS (VAG-COM) codes and programmable options for Golf Mk7 - Page 38
