It should be there in adaptions. Did you try the search box? I don't use OBD11 so i don't know if there is a searchbox but i've coded Traffic sign on multiple 7.5 so i know it is possible.
Printable View
I'm indeed a novice with OBD11 but I am looking to buy one for myself. Can anyone recommend a good unit that has an ios app not android. Sorry if there are recommendations on other threads that I haven't found. If someone could point me to the right thread or in the right direction I would really appreciate it.
iant333: how about VCDS- one of the "HEX" series products if you have a new-ish car. VCDS uses a MS-Windows platform, but I'm aware that some folk use Bootccamp as the intervening platform. I'm sorry that I can't help further - I stopped buying Apple products when Mr Jobs restricted connectivity to his devices. IMO, the real genius @ Apple was the other Steve (i.e. the Steve that actually designed stuff)
Of course, if you chose a HEX-NET, then you could use VCDS -mobile because this doesn't require anything on your IOS device besides a browser,
Anyone know if I can activate the fatigue detection system under Driver Assistance menu via VCDS or it's not possible?
Thanks.
