^ Correct Don.
This is what I copied off another UK forum:
OK, here it is (courtesy of Golf mk7 FORUM):
Go to:
- A9 Struct. Borne Sound
- Adapation 10
- Select "channel of structure borne sound " (only choice)
- Std value 100% - change to the value you want stored in % (60% has been suggested as a good happy medium, adjust to 0% if you want no noise/mini vibrations).
- "Use change code for change approval"
As above, I am planning on setting volume at 60% which from others who have done this appears a happy compromise (0% would of course = mute)
readerr0r: It's always good when I don't know stuff because I learn something new! Zloybob didn't answer my question about how the long coding string from my car could be used for his Discover Pro screen. I would have thought that a byte-by-byte comparison of the coding for the two MMIs would be unworkable. Any ideas ?
Very likely, usually the units come from different brands so there's slight differences between exact coding. I haven't had a chance to do much with Golf 7/Octavia 3 coding yet so I don't have in-depth knowledge. Getting SUNA working on the Octavia's Discover Pro is on my personal to-do though.
Plus the other Octavia coding bits and bobs, laptimer, show speed limit on the colour MFD, DRL off on indicate etc.
Just a shame that there is nowhere to type 1024 into in VCDS for the RNS510 (I looked)
Sounds doable
btw when digging around the RNS510 in VCDS I saw a setting described as 'Eject Lock' -wonder if that has anything to do with some of those guys who couldn't eject firmware CDs after botched update attempts.
There are plenty of places where you can type it
