Page 125 of 198 FirstFirst ... 2575115123124125126127135175 ... LastLast
Results 1,241 to 1,250 of 1974
  1. #1241
    UserName123: Hi - I note that your location is "Hell"! Are you a devotee of Dante's 14th-century epic poem "Divine Comedy", and is there a sign over the gates there saying "Abandon hope all ye that enter here"?
    Anyhow: to your question - I'm not sure but if you post-up an adaptation channel map of the module @ address hex09 (which VCDS calls the "BCM"), then I'll have a look at what's possible in the new Golf
    Not quite hell, but the city I'm from does start with the first three letters so quite close.
    And allright I can post it, first I'll have to see how to do it.
  2. #1242
    Quote Originally Posted by UserName123 View Post
    Arrh I see - Helsinki!!
    Thanks for the admap. It's the first that I have seen for the new-look Golf and you are correct - there has been much that has changed in the BCM.
    I will need to have a look at the connection pin-out for the new BCM to make sense the channel settings, but it appears at first glance that the only headlight Leuchte-sets that are used are the low-beams. Clearly the new LED based headlight fittings have been integrated into the Convenience CAN bus in a different way to the older models - intriguing. The leuchte-sets for the taillight fittings appear to be more traditional, but there are still some significant changes!
    Incidentally, this BCM is one of the new version that doesn't have any code-string. Instead, all the software switches that were in Byte/Bits, are now embedded into adaptation channel settings - making the channel count in this BCM a whopping 2,040-ish!
    So- my apology, but I don't believe (at this time) that it's just a matter of energizing additional Leuchte-sets to get the two inner LED bars to operate as you want. But as I said, my understanding of this new arrangement is not good - perhaps another forum member here can be more helpful
  3. #1243
    Here is a link to the map: Dropbox - adpmap-09.CSV
  4. #1244
    DV52, do you need some additional information perhaps ?
  5. #1245
    Username: hmmm....... I have to admit that I can't find anything remotely appropriate in your BCM admap. The traditional 4 x DRL Leuchte sets are:
    • Leuchte2SL VLB10
    • Leuchte3SL VRB21
    • Leuchte4TFL LB4
    • Leuchte5 TFL RB32
    I was hopeful that I would find a pair of these Leuchte-sets that simply needed to be energized to address your problem. But alas, all 4 x Leutche-sets are not activated in your BCM - which as I said previously suggests that these LEDs in front headlight fittings on your car are controlled by another method (interesting!).
    How would you feel about sharing the auto-scan report on your car? You can remove the VIN from the report before posting it here if you want (for anonymity)? That way we can see what other equipment is fitted to the vehicle - which hopefully might reveal an alternative path of inquiry.
    I also need to get hold of a wiring diagram for the vehicle - this is often a valuable resource when dealing with these problems. But this takes longer time.
    PS: if/when you post-up the auto-scan, remember to use the "code" tags: before you paste the data , add [code] and at the end add [ /code] without the space between "[" and "/" . Here's an example of how it should look:
    Code:
    Tuesday,25,March,2014,11:55:50:03521
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 14.2.1.2
    Data version: 20140212
    VIN: ********   License Plate:
    Mileage: 6411 kms   Repair Order: Beta Ver 14.2.0
    Chassis Type: AU (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
    VIN: ***********
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    Address 01: Engine (J623-CHPA)       Labels: 04E-907-309-V1.clb
       Part No SW: 04E 906 016 G    HW: 04E 907 309 A
       Component: 1.4l R4 TSI   H08 5272
       Revision: WAH08---
       Coding: 01250032242405082000
       Shop #: WSC 00028 028 00079
       ASAM Dataset: EV_ECM14TFS01104E906016G 002006
       ROD: EV_ECM14TFS01104E906016G.rod
       VCID: 26431A2059EACC04DD-8073
    No fault code found.
    Readiness: 0110 0001
    Address 02: Auto Trans (J743)       Labels: 0CW-927-769.clb
       Part No SW: 0CW 300 045     HW: 0AM 927 769 G
       Component: GSG DQ200-MQB H43 4510
       Revision: 00043014    Serial number: CU501212296246
       Coding: 0014
       Shop #: WSC 00028 028 00025
       ASAM Dataset: EV_TCMDQ200021 001001
       ROD: EV_TCMDQ200021_AU37.rod
       VCID: F6E38A6049CA7C842D-80A3
    If you click "Reply with Quote" tab on the lower RHS of this post, you will see how the "code" tags operate
  6. #1246
    I ask if it is possible to activate via the VCDS the engine oil level function visible from the central console or from the composite media display.
  7. #1247
    May 2016
    singapore
    Hi Don- DV52
    I recently added a VW Helix amp / subwoofer to a non fender / non DynaAudio Golf MK7.
    While the sound has now become somewhat better, there is not a lot of flexibility to made/customised the sound.
    Would you have tweak to Adding of equaliser function to the MIB2.?
  8. #1248
    No but you can change sound level outputs.
  9. #1249
    May 2016
    singapore
    Quote Originally Posted by Diegothecat View Post
    Thanks for the reply. Do you mean the small screw at the DSP or via the VCDS.
  10. #1250
    Quote Originally Posted by samuelk View Post
    Using VCDS,
