Originally Posted by
scaper28
Craig: What a very interesting problem - thank you for raising it!!!
Fortunately your car and mine have the same BCM - see as follows:
scaper28 - BCM
Code:
SW:5Q0-937-084-N HW:5Q0-937-084-N --- Cent. Elect. --- SA: 03147,,,,
;Component:BCM MQBAB M H14 0106, Coding:03000842C241027B0FA44080B1040328100A000000000000000000000000,,,
;EV_BCMCONTI,10001,EV_BCMBOSCH_010.rod,,
;Thursday,29,June,2017,08:31:39:20275
;VCDS Version: Beta 17.6.0 (x64) Data version: 20170602 DS274
DV52 - BCM
Code:
SW:5Q0-937-084-N HW:5Q0-937-084-N --- Cent. Elect. --- SA: 31347
;Component:BCM MQBAB M H14 0106, Coding:03001842C24102FB0FA4400000040308100A000000000000000000000000
;EV_BCMCONTI,010001,EV_BCMBOSCH_010.rod
;Friday,30,June,2017,18:20:07:16808
I was able to replicate your problem by creating an Admap of my BCM using the same Beta software version as in your file (i.e. Beta SW ver 17.6.0). I then compared the ver 17.6.0 admap with an admap from a previous Ross Tech version (i.e. ver 16.8.0)
I was pleasantly surprised to discover that the latest Beta version software found 78 x new adaptation channels in my BCM that were previously unknown.
However, I also sadly discovered that the latest Beta verion software lost 68 x old adaptation channels from my BCM that were previously known
Here is the list of the Adaptation channels that were lost from my previous version SW (I've highlighted your missing channels):
Code:
ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung
ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1
IDE01268-ENG02321-Windshield wiper-Tippendes_Frontwaschen
IDE01268-ENG02322-Windshield wiper-Frontwischer_Abtauposition
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant
IDE02269-ENG02272-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl
IDE02269-ENG02273-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl
IDE02711-ENG02323-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1
IDE02711-ENG02324-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2
IDE02711-ENG02325-Rear Window Wiper-Einzelansteuerung Heckintervallwischen
IDE04923-ENG02307-Turn signal control-Abbruch Komfortblinken
IDE04924-ENG126816-Driving light and parking light-Standlicht aus
IDE04927-ENG126845-Window heater-FSH Automatik
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel
IDE05142-ENG02314-Access control-Heckfreigabe_Ohne_Verzoegerung
IDE05142-ENG02315-Access control-Deaktivierung_Laderaumschliessung_extern
IDE05142-ENG02316-Access control-LS_Taster_Togglefunktion
IDE05142-ENG02317-Access control-Nutzfahrzeug_Schliessung
IDE05142-ENG02318-Access control-Wiederverriegelung_Laderaum
IDE05142-ENG06090-Access control-Mindestbetaetigung_HDF_Innentaster
IDE05142-ENG115722-Access control-Elektrische Laderaumabdeckung
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe
IDE07470-ENG02308-After-run for park light-Bedingungen zur Standlichtbegrenzung
IDE07470-ENG02309-After-run for park light-Bedingungen zur Parklichtbegrenzung
IDE07470-ENG02310-After-run for park light-Faktor fuer Verfgbarkeitstimer
IDE07470-ENG02311-After-run for park light-Standlicht-Verfgbarkeit
IDE08542-ENG02339-Access control 2-Spiegelanklappen_bei_Wiederverriegelung
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus
IDE08542-ENG125656-Access control 2-Regenschliessen_art
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel
IDE08542-ENG128459-Access control 2-easycloselight_aktiv
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken
IDE10298-Alternating park position 1
IDE10299-Alternating park position 2
MAS01490-ENG02328-Energy management-Praediktives_Energiemanagement
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation
MAS05934-ENG02319-Convert. top oper.-Remote Lock Unlock Timer s1
MAS05934-ENG02320-Convert. top oper.-Remote Lock Unlock Timer s3
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein
Just to be clear - the list above are those adaptation channels that appeared in the BCM admap using version 16.8.0 BUT do not appear in the BCM admap using Beta version 17.6.0
Alas, I have no idea why this has happened - I suggest that you contact Ross Tech for a response. However, if you want to proceed with the tweak - please use a previous release VCDS version
