Originally Posted by
komoornik
Just got MY17 Golf Sportsvan (SV).
I am having issues with some important codings.
I cannot change DRL operation (so they won't be on when switch is on parking lights or when parking brake is applied) - channels are not available. Cannot seem to also get them to show up in lights menu.
Also cannot change at all CH/LH settings. Wanted to switch them from main beam to fog lights and also enable automatic CH.
BCM: 5Q0 937 086 BG
komoonik: Hi and welcome to the forum - the reason why you can't find the adaptation channels is because the boffins on the VW mother ship redesigned the database for the BCM on late model MY16 and MY17 vehicles. Alas you will find many tweaks affected by this change. But, in the main, the modification only applies to the "Parent" part of the channel identifier - the "Child" part generally has been left unmodified, fortunately. I've also heard that in some new BCMs, the magic number 31347 no longer works!
So, I'm assuming that you have VCDS:
- for the DRL parking light tweak, look for ENG10575-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht
- for the DRL using the handbrake, look for ENG10575-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten
- for the Coming home lamp selection, look for ENG10575-ENG115833-Außenlicht_Front-Fahrlicht bei Tag
