Originally Posted by
Juzam
I was fiddling around with my friend's MK VII Golf and I messed up the instrumentation coding. Now the fuel consumption gauge is behaving strangely. It keeps getting higher when coasting in neutral instead of dropping, and gets lower when pushing the accelerator! It's like reversed. But I didn't do anything related to fuel consumption in long coding and adaptation. I reversed some coding I've done but it didn't help. And I have lost the autoscan file
Can you help me please? What should I look for?
Juzam: Hello and welcome to the forum.
Wow, I have never heard of those symptoms - I would like to know how you did that (it's an interesting effect)!
Whilst you may have lost your autoscan file (how did you do that?), I'm hoping that you still have your CodingLog.CSV and ApdLog.CSV files. Just look in the Ross-Tech/Debug directory on the laptop that you used to make the changes. As the names imply each of the files will contain a record of the code-string and adaptation channel changes. The records contain both the before and after values - just revert to the original settings
