Originally Posted by
badufay
Hey Don, coming over from a 15 Golf (US) to a 2017 GTI (US) and have seemed to run into the instrument access code issue. I've seen a lot of talk about using VCP to pull the codes, I have both VCP and VCDS, how can I help with VCP to try to get the access code for instruments?
Ben
Ben; Congratulations on the new car - is VW still putting the steering wheel on the passenger side of their vehicles up there?
So - happy to describe the process for security code discovery using a VAG CAN PRO cable, but a couple of caveats prior to the explanation to put the forced-polling procedure in context:
First - As you already know from your VCDS experience, VW's control modules tend to get cranky if an attempt is made to enter an incorrect security code (they shut-down for a period of time measured with the ignition switched-on time). Forced polling of unknown security codes will result in the same outcome if not done properly! The way that VCP gets around this forced shut-out outcome is by first opening the control module with a known security code. Think of this as the key to open the module
Second - In discussion with Ross Tech, I have been told that VW are/have been reconsidering their security code protocols - which is disturbing for us all!! There is apparently a rumor floating about that 6 digit security codes could arrive soon (or they may already be used) - what evil satanic mind even thinks about using a 6 digit security code?
. There is also another rumor, which RT believe to be true, that VW has closed the loop-hole in the module's firmware that opens-up the control module for forced polling. I'm not sure, because I haven't been able to get my hands on a late version mk7 to confirm these hypotheses!
With these caveats as a backdrop- this is the process for using VCP LoginFinder:Connect and open the Instrument control module @ address hex17
As shown in the screen shots above, select
Sec. access button, then select
LoginFinder - you should then be presented with the following screen:
The entry variables for this screen are as follows:
- Known login - is the security code that "opens" the module - as described above. The only known code that I'm aware-of for the instrument module on yor car is 25327!
- Range: Start - clearly this is 00000 if you are starting from scratch (assuming your module uses a 5 digit security code), but if you are poling in batches, then simply adjust the number to suit
- Range: Stop - the upper limit
- Reconnect before try- the process will disconnect then reconnect the module before each polling attempt. It only works with this ticked - for me
- Standard Diagnose - I've only been successful using this option. Try the other options, but they haven't worked for me
- Reconnect delay - this is the time delay (in milliseconds) between the beginning and end of communication packets. Obviously, the lower the number, the quicker the process works - however, I've found that making the polling process faster can cause instability, which results in the failure. I've found 10 (msec) to be about the quickest with pre MY16 modules
- Tries between recovery – this determines how many attempts happen between failed login tries. I've only had success with 2 in this box
- If you get any successful attempts, the security code is shown on the RHS box. Press Save when the process is completed - this will automatically load the successful security codes when next you access this module
- In the area that says "finished" (bottom of the screen) in the picture, you will be able to see the current number being polled and the estimated time for the process to complete
Good luck - the adulation, admiration and respect of your compatriots as well as all of us on this forum awaits if you can crack this problem!!
