Page 104 of 198 FirstFirst ... 45494102103104105106114154 ... LastLast
Results 1,031 to 1,040 of 1974
  1. #1031
    Quote Originally Posted by jimmyjamesred View Post
    See screenshot. I've got a MY17 GTI hatch.
    Jimmyjames: OK "Golf Variant" works for me - it looks like this:
    VCDS (VAG-COM) codes and programmable options for Golf Mk7-vw-golf-vii-variant-01-jpg
    Kind-of looks like the "station wagon" on your first post. If you check the Codinglog.CSV file that lives in the Ross-Tech/Debug directory on the laptop that you used to make changes, you should see a record of when the change to the code-string was made to the car. Just look for records that have Address 5F in the first column.
    Anyway, try changing the value of these Bytes to 027300 - as per my screenshot
  2. #1032
    Dec 2016
    brazil
    is it possible to set the "CAR" page of the infotainment screen to always begin in the 'SINCE START' page (i.e., not in the vehicle status page) ??
  3. #1033
    Oct 2016
    Sydney, NSE
    Awesome thanks for that. I think I worked out what I did. I used the long coding helper to deactivate the safety warning.
    I think as I was arrowing down through the bytes I must have inadvertently scrolled through the drop downs to select the Variant in the first byte. Anyway I copied the original coding from the log and then changed the 2 to a 0 to disable the warning again. Voila, I have a GTI hatch again on the screen. Cheers!
  4. #1034
    Dec 2016
    brazil
    Quote Originally Posted by gaucho View Post
    Anyone with experience in this?
  5. #1035
    Jan 2012
    My Vehicle status only shows up first when there is a message such as door open or fuel needed, otherwise what comes up first is what I last left it on.
    2015 Golf R. Lapiz Blue.
  6. #1036
    Dec 2016
    brazil
    Quote Originally Posted by Reedy View Post
    that's exactly how I would like it to do, but here it always come to the Status screen. Is it possible to fix?
  7. #1037
    Mar 2015
    Warner, QLD
    Try this:
    Before you power on the car, close all your car doors first. It should just go to the last page.
    Door open, low fuel, service reminder or any other warning will hijack your screen.
    I agree tho, it's nice that it tells me my door is open, but it should return to the original screen once I have closed my door, and there are no other statuses to show...
    Golf MK7 103TSI Highline Wagon | Limestone Grey | DAP2
    Golf MK7 110TDI Highline Hatchback | Tungsten Silver | DAP
  8. #1038
    May 2012
    I leave mine on oil temp but If you make a call, put in a address to Nav to it will change to that until you switch it back. It's just what it does.
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
  9. #1039
    Dec 2016
    brazil
    Quote Originally Posted by agentthumb View Post
    Try this:
    Here even with no warnings it goes back to Status, is there any vcds config to change that? Doors open I can see in the driver's panel, no need to see it in the central panel screen.
  10. #1040
    Mar 2015
    Warner, QLD
    I don't believe so. Others might know tho.
