Originally Posted by
mcan616161
Hi
How can I activate eco suggestion information with Vcds?
@mcan616161: Hi. I'm not entirely sure what you mean by "eco" and it really does depend on model build date and module level (low, medium, high) - but try setting the adaptation channels below to active in the CAN Gateway module @ address hex19.
Code:
IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch)
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system
IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof
IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button)
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill
IDE06753-MAS06289-Efficiency program display-Comfort use A/C
IDE06753-MAS06290-Efficiency program display-Comfort use parking heater
IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater
IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater
IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater
IDE06753-MAS06295-Efficiency program display-Comfort use fog light
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light
IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission
IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater
IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation
