Results 1 to 5 of 5
Thread: Vcds eco suggestions activation
    Jan 2021
    germany
    Hi
    How can I activate eco suggestion information with Vcds?
    Quote Originally Posted by mcan616161 View Post
    Hi
    @mcan616161: Hi. I'm not entirely sure what you mean by "eco" and it really does depend on model build date and module level (low, medium, high) - but try setting the adaptation channels below to active in the CAN Gateway module @ address hex19.
    Code:
    IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof
    IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM
    IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start
    IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch)
    IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system
    IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system
    IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof
    IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D
    IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill
    IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button)
    IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill
    IDE06753-MAS06289-Efficiency program display-Comfort use A/C
    IDE06753-MAS06290-Efficiency program display-Comfort use parking heater
    IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater
    IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater
    IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation
    IDE06753-MAS06294-Efficiency program display-Comfort use rear heater
    IDE06753-MAS06295-Efficiency program display-Comfort use fog light
    IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light
    IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission
    IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater
    IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater
    IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater
    IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater
    IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation
    Jan 2021
    germany
    Hi
    Thanks for your answer
    They all seem to be active on my system. I think something is off in the 5f menu.
    @mcan616161: OK - if the channels are already activated, isn't there an option under MENU (press the "Car" button) to turn ON/OFF the tip function?Don
    Jan 2021
    germany
    Car settings not available in dashboard option.
