Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Tyre Pressure Warning + random coincidence has me questioning my sanity
    Apr 2010
    My tire pressure monitoring went off the other day on my GTIPP as I was about to drive from Sydney to Newcastle for a work.
    The day before I'd pumped all the tires to 40psi and the rear inside tyre was reading about 32psi.
    Rolled the car backwards looking at the tyre in as many spots on the wheel as I could - didn't see anything.
    Thought I had a slow leak, got home after 2 days after looking multiple times at the tyre and found a screw on the inside of the wheel.
    So it needed about 8psi difference on one wheel before it would indicate an issue.
    MY21 Golf MK8 GTI | Kings Red Metallic | all options |
    MY16 Golf MK7 GTI PP | White | With Leather |
    MY11 Golf MK6 GTI DSG | CW | 5dr | Bi-Xenons | ACC | 18" Detroits | RNS510 with Dynaudio| RVC | MDI |
    Jul 2012
    Quote Originally Posted by AJW View Post
    Interesting, although my pressures were all the same when I checked. If nothing goes off early on my drive to work, I'll stop by a servo and test the pressures again.
    2016 GTI Performance | Pure White | JB1 | Dog Bone | Full Tint | Stop/Start Delete | Avatar by sandwg
    May 2013
    From my experience, it seems to be only helpful if you have a big loss of air suddenly. I check my pressures every 3-4 weeks and I see movement of 2-4 psi across all 4 and it never goes off.
    MY08 Mk5 GT Sport - sold
    Jul 2012
    Well everything checked out today. No repeat issue and all parts are definitely still on my car. Case closed due to lack of sufficient evidence.
    May 2014
    Newcastle, NSW
    My GTI PP has done the same thing a couple of time. I wouldn't be too worried about it. The method it uses to calculate low pressure isn't too reliable.
    Jul 2012
    Quote Originally Posted by turtle View Post
    First time it's happened to me so I was obviously a bit thrown, especially with old mate flashing the lights!
    Aug 2015
    Perth, WA
    How are you enjoying the PP Mattaus? Any tune yet?
    Jul 2012
    The car is great, although no tune yet. A change in personal circumstances may see a need to upgrade to a larger car though
